Sponsored by: Auxito
Sound from steering column
Old Mar 22, 2007 | 04:07 PM
dafireman's Avatar
dafireman
I have a sound from the steering col. of 03 150. It is faint, but sounds like someone running thier fingernails over nylon!!! I raised the hood and you can't hear it from there, only the in the cab. Does something in the column need lubed?Of course it only does it when you turn the wheel. Anybody??
Old Mar 22, 2007 | 06:19 PM
beer boy's Avatar
beer boy
check for wires or sound deadining material where the column goes through the fire wall. the fluid level is fine right?
Old Mar 22, 2007 | 07:03 PM
dafireman's Avatar
dafireman
Yep, fluid is fine. It just started to day. It sounds like it is right at the wheel and the column if that makes any sense.
Old Mar 22, 2007 | 07:33 PM
screwy's Avatar
screwy
I had it happening for awhile, turned out to be a piece of foam that had come loose and started rubbing on the shaft.
Old Mar 23, 2007 | 06:26 AM
dafireman's Avatar
dafireman
Thats probably what has happened to mine. I have a bad habit of using my steering wheel for drum set while I am driving!! Thanks.
