1978 - 1996 Big Bronco
fuel guage??
Old Mar 22, 2007 | 06:04 AM
janedoe77's Avatar
janedoe77
fuel guage??
ok i just bought an 88 bronco , 302 engine 4x4 , my fuel gauge doesnt work how can i test it? i got the manual on it but it makes no mention of it. im prolly gonna be on here quite abit, juat advance warning lol
Old Mar 22, 2007 | 07:06 AM
moemeadors's Avatar
moemeadors
Do a search for "fuel gage" I remember a post on here somewhere that helped me troubleshoot my problem. Usually it's the sender or the float. Good luck with your new project.
Old Mar 22, 2007 | 08:09 AM
Kemicalburns's Avatar
Kemicalburns
the fuel gauges themselves rarly fail. I have that same bronco and it was the sending unit on the pump, i went to ford and got the complete pump,sender,float assembly for $120. most auto parts stores dont sell this complete setup.
when i pulled it out i found the sender of course bad and the float had fuel in it.
If you unplug the wire from on top of the tank and ground it out the gauge should move. this will tell ya. make sure you have little to no fuel in the tank if you do have to drop it. the job isnt bad just a bit time consuming.
Old Mar 22, 2007 | 08:28 AM
janedoe77's Avatar
janedoe77
Red face thank u
sweet ill try that , so ford is the only one to get it from?
Old Mar 22, 2007 | 08:56 PM
3broncocrazy's Avatar
3broncocrazy
Yep, sender or complete assy from Ford, you can find pump at other auto parts stores........before the tank drop, do more troubleshooting first, like fuse, wiring, conections, ...etc.
