Need tranny advise
Old Mar 21, 2007 | 11:30 PM
wnarace's Avatar
wnarace
Need tranny advise
While driving my x today I stepped down to pass, the tranny downshifted down two gears, increased rpm but didnt seem to increase mph. I then backed off the throttle to approx. 80% and then it began to pull like normal. The simptoms only appear at wide open throttle. Any advise is greatly appreciated.
Thanks
Troy
Old Mar 22, 2007 | 01:11 PM
njstevens's Avatar
njstevens
What engine are you running? Any work done or afternarket chips?
Old Mar 22, 2007 | 01:36 PM
wnarace's Avatar
wnarace
I am running a v10 with no mods. I happened to run into a ford tech today a lunch and he said it sounded like a fuel filter issue. Does this make sense?
Old Mar 22, 2007 | 02:53 PM
1's Avatar
Were RPMs increasing but speed stayed the same? Thats more then likely a slipping transmission, or possibly a bad torque converter but i doubt it if its running fine otherwise. If RPM's are rising in a gear, the vehicle should accelerate.
If it was a clogged fuel filter you would go lean, have a very noticable fall on its face feeling when it went to high rom, and possibly some loud popping noise like a muffled backfire. Bottom line, if your RPM was going up, you were getting fuel, and you were not accelerating. All symptoms point to trans/torque converter in my eyes.
Remember at high RPM you are making more power taht the transmission has to hold. If its on its way out, this is when it will slip, under heavy loads.
Old Apr 12, 2007 | 05:07 PM
rbaker6336's Avatar
rbaker6336
sounds as though the weak T/C is deciding to go south
Old Apr 12, 2007 | 05:46 PM
XylemXorro's Avatar
XylemXorro
Oh man, I thought this thread was about psychological issues
Old Apr 12, 2007 | 07:12 PM
wnarace's Avatar
wnarace
Not this time LOL.
Well it turned out that the output shaft speed sensor on the tranny was junk. A simple change of the sensor and back to business as usual.
Thanks for the reply's.
