Squeeking front end
Old Mar 21, 2007 | 10:26 PM
Jimmygunz3's Avatar
Jimmygunz3
Squeeking front end
I have a 99 eb expo and the front end is really squeeking every time I hit a bump or turn the steering wheel, If i shake the truck it squeeks, I am having a hard time pinpointing it, I tried wd40 on all the tie rods and bushings. I know it is a known problem on fords. Does anyone have any input on this matter. thanks
Old Mar 22, 2007 | 08:50 AM
johnpvb's Avatar
johnpvb
Just had my Expy fixed for the same problem. It had low miles, but it was the idler arm. I've seen other posts where it could be the lower/upper ball joints. Luckily, I dodged that bullet.
Old Mar 22, 2007 | 09:48 AM
KR1's Avatar
KR1
OT, but i had the same problem on my 99 Taurus, and it was both Stab links (The are different design than our EXPYs), and a tie rod end.
I have almost got the toe in adjusted my self (Who needs an alignment shop).
Old Mar 22, 2007 | 09:58 AM
SMIGGS's Avatar
SMIGGS
I had somewhat the same problem except mine was more a "clicking" sound coming from the passenger side. Believe it or not it removed the battery and tray and there is a metal clip for the tray on the wheel well that was for some reason making that clicking sound. I sprayed it with some lithium grease and haven't heard it since. ( over a year ago )
Old Mar 22, 2007 | 10:08 AM
Omahastro1's Avatar
Omahastro1
I had a squeek and when I replaced the front shocks it went away.
99EB with LLS
Old Mar 22, 2007 | 03:44 PM
Jimmygunz3's Avatar
Jimmygunz3
I have a feeling it is the shock on the drivers side , prob will replace it and see what happens
Old Mar 27, 2007 | 05:48 PM
99ExpyProblems's Avatar
99ExpyProblems
mine was the Lower control arm bushings. Exact same problem and when it rained, people would be staring at me when I went over a speed bump. It was the most annoying noise in the world.
I took it to a mechanic who said he could just replace the bushings. $200 later I was running fine. A week later, and it was squeeking worse than before.
Cost me $300 to have the driver side replaced at Ford. 6 months later, and no squeaking. Ford doesn't replace the bushings, they replace the whole A-frame.
Old Mar 29, 2007 | 08:38 AM
Trucker22's Avatar
Trucker22
squeak
Mine was the front shocks---I think Pass side. Squeaked for 80K from new--put in new air shocks and she's quiet. 2000 Nav with LLS.
Old Mar 29, 2007 | 12:14 PM
bubahyde's Avatar
bubahyde
I have seen this on many different trucks.
Your MOST LIKELY cause is the Lower Ball Joint
I know the noice is AWFUL.
My wife questioned its safty.
(Do each side separetly)
1. Lift the truck by the Lower Control Arm (Unload the ball joint)
2. Turn your wheel back and forth.
3. Most likely the noise will be gone, "Lower Ball Joint Replacement"
4. If it is still there, look closer at the Tie Rods and Idler Arm.
Old Mar 29, 2007 | 05:11 PM
RAGaz's Avatar
RAGaz
It was the idler arm on my '01 Expy.
