multiple random Cylinder Misfire
Old Mar 21, 2007 | 09:36 PM
MyBlueCrew's Avatar
MyBlueCrew
Help. It show this code and then a misifre on #2. The first code I got a week ago was misfire on # 1. Change the plugs about 2 weeks ago. Kinda odd all on the same side of the engine.. Any help would be great.. The engine is running real bad like a couple of cylinders are dead.... mommas car ....well you know how this goes lol
Thanks,
Scott
98 Expedition EB 4x4 5.4
Old Mar 21, 2007 | 11:15 PM
bridge's Avatar
bridge
Sick 'n Tired
I'd check to make sure the coil packs are all seated on the plugs by pulling them off and re-seating all packs on the affected side of the engine. Also, could be a bad coil.
Old Mar 22, 2007 | 12:33 PM
buzzard's Avatar
buzzard
Did you coat with dielectric grease before re-assembly? Check boots for damage.
Old Mar 22, 2007 | 07:02 PM
MyBlueCrew's Avatar
MyBlueCrew
Thanks guys going to check a few things!!!! Momma is ...lol
Old Mar 22, 2007 | 11:14 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Swap your #1 and #2 coils with #5 and #6 coils. Then if the misfire changes, you'll know the culprit.
Old Mar 22, 2007 | 11:19 PM
RangerPilot's Avatar
RangerPilot
If it doesn't move, you're looking at spontaneous injector issues or a head gasket problem.
