Sponsored by: Real Truck
Front Hitch Done!
Old Mar 21, 2007 | 09:31 PM
bczolone's Avatar
bczolone
Front Hitch Done!
Well first off those who said they did it in 30min to an hour either had a different hitch, help, or were on crack; making time fly! J/K...
The Bad : The hitch was severly scratched, fit was OK, not great, the bolts with the handles that come with the hitch are there because its SUPER difficult to put them on thus the need to have handles on them. What was not taken into account was how to put the washers on??? I used double sided tape...it also helps to have skinny arms and I HAD to remove the grill. The biggest problem was realigning the front bumper and after using a floor jack and 2 "C" clamps got it within 1/8 " of original fit.
The Good: I followed all directions without much problem aside from improvising the tape for the square washers and grill removal it was a simple task and all said and done I think it will serve muliple purposes for which it was intended. Glad I now have it. I also added the lic. plate holder since here in CA you have to have a front lic. although I don't know what I'll do if I use a bike rack.
The pics are in my gallery.
Old Mar 21, 2007 | 09:40 PM
99f350sd's Avatar
99f350sd
What brand? Mine was easy..but its a 99.
Dick
Old Mar 21, 2007 | 10:03 PM
bczolone's Avatar
bczolone
Hidden hitch? Anyways I didn't devote myself, just worked a little after work each day but I would'nt call it easy. My aux tank was easy. My roll-top bed cover was easy; this is the most difficult mod I've done so far on this truck, I've installed lift kits that overall were easier...not time wise. Anyways I would have been easier with a helper.
Old Mar 21, 2007 | 10:08 PM
99f350sd's Avatar
99f350sd
Mine was drawtite. Just remove the 4 bolts for the bumper and it comes off. The hitch was one piece with eight bolt holes. I think I had to drill 4 holes slap the hitch on -the bumper on top of that and install eight bolts..I think that was it. I use it for my winch.
Dick
Old Mar 21, 2007 | 10:25 PM
bczolone's Avatar
bczolone
Yeah mine says draw-tie on the order slip...well anyways the extra nuts, and washer were a bear to get in, but the biggest problem was line up, side to side...had to use a jack and claps, but I was by myself.
Old Mar 21, 2007 | 10:31 PM
99f350sd's Avatar
99f350sd
I think cause you have an 04..
Dick
Old Mar 21, 2007 | 11:32 PM
BobbyDiesel71's Avatar
BobbyDiesel71
what are you going to do with the hitch?
Old Mar 21, 2007 | 11:54 PM
bczolone's Avatar
bczolone
Its mostly to move my trailer in and out of my back yard. Its a tight fit about 6 inches either side of the gate. I had one on my last two trucks and it was a lot easier when backing the trailer in up a steep incline through such a tight spot to do it looking forward, plus you can turn the trailer quicker...I also might use it with a bicycle hauler.
Old Mar 21, 2007 | 11:57 PM
BobbyDiesel71
I installed mine last year thinking I was going to buy a Warn winch with a multi-mount to use either at the front or rear of the vehicle. I may just remove my prerunner bar and install a ARB bumper.
Old Mar 22, 2007 | 10:40 PM
TP83's Avatar
TP83
bcz front trailer hitches are great we have one on our 350 and it makes trailers so much easier to push around. as for having a front plate try fabbing something up just a piece of square tubing and a flat sheet of metal, weld it together drill the hole and put it right into the hitch. then just use a pin to hold it on for quick use.
Old Mar 23, 2007 | 10:15 AM
bczolone's Avatar
bczolone
I bought the front plate holder with it, but it sticks out about 2 inches.
Old Mar 23, 2007 | 07:43 PM
Ronin007's Avatar
Ronin007
bczolone - nice post and pictures that you took of the install.
Dick - how was the clearance of your hitch with you plow mount? I am curious as I have considered doing the same thing, but have been concerned about getting around the plow mount.
Old Mar 23, 2007 | 08:59 PM
99f350sd's Avatar
99f350sd
My hitch is inside of the bumper about 1". I had to grind a little to get it to fit if I remember correctly around the plow metal near the frame horns..Not a big deal.
Dick
