2004 electrical questions
The lights on dinger is a little more difficult to get rid of, but I do remember seeng it around here somewhere. Do a search.
Also, you didn't mention it, but the sequence for disabling the seat belt dinger is in your manual. It should be a sequence of buckling/unbuckling the seatbelt 10 times. I have found that 2 seconds buckled, 2 seconds unbuckled seems to be about the perfect pace to accomplish the sequence.
Under the steering colomn there are three screws that need to be removed. You will see a pink (I think it is pink, if I remember right) wire coming from the end of the key toumbler. It will be failry easy to see the wire on the end of where the key should go. Just cut the wire and tape the end back that is going down the colomn.
Hopefully someone will be along soon to just ok this and make sure that is EXACTLY how that mod should be done, but I think that is how I did mine...its been awhile, so I am having problems remembering...
To program the keyless entry keypads remote entry transmitters yourself:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 2 (LOCK) position to 3 (OFF).
4. Cycle eight times rapidly (within 10 seconds) between the 3 (OFF) position and 4 (ON). Note: The eighth turn must end in the 4 (ON) position.
5. The doors will lock, then unlock, to confirm that the programming mode has been activated.
6. Within 20 seconds, program the keyless entry keypad by pressing the 7•8 and the 9•0 controls at the same time.
7. The doors will lock, then unlock, to confirm that the keypad programming mode has been activated.
8. Within 20 seconds, program the remote entry transmitter by pressing any button on the transmitter. Note: If more than 20 seconds have passed you will need to start the procedure over again.
9. The doors will again lock, then unlock, to confirm that this remote entry transmitter has been programmed.
10. Repeat Step 8 to program each additional remote keypad or entry transmitter.
11. Turn the ignition to the 3 (OFF) position after you have finished programming all of the remote entry transmitters. Note: If more than 20 seconds have passed you will need to start the procedure over again.
12. The doors will once again lock, then unlock, to confirm that the programming mode has been exited.
Pretty much if you do steps 1-4 and step 5 happens then your truck has remote entry.
