Sponsored by: Auxito
How Bad Is It...?
Old Mar 21, 2007 | 03:54 PM
drj777's Avatar
drj777
Exclamation How Bad Is It...?
...i just installed my first program...and thought i had removed the fuel pump fuse (@ first i DID - and then i mistakenly put it back)
painfully - i realized this just before the program was finished installing.
however - i never started the car...i returned it to the stock program and then started the truck.
seemed fine.
then - i removed the fuse (AGAIN) and re-installed the tuning program - then started the truck.
seems fine.
so i know im an idiot...but is my truck gonna be ok?
drj
Old Mar 21, 2007 | 04:29 PM
FTE Ken's Avatar
FTE Ken
Yes, your truck will be fine.
Removal of the fuse is to keep the fuel pump from over-heating if the fuel level is low and also to prevent low voltage when installing the program if your battery is marginal. So long as the program is installed without failing in the middle of installation it'll be fine.
Old Mar 21, 2007 | 05:09 PM
drj777's Avatar
drj777
Talking
THANKS!!!
now i can rest easy...
i appreciate the help!
drj
Old Mar 21, 2007 | 07:25 PM
liquid 1's Avatar
liquid 1
Page 12 section 11 in the owners manual for your 03, Humm it says ford requires the fuel pump fuse to be removed, and if not removed it could cause severe damage, straight outa the superchip manual, So it could cause damage if like the above post states low voltage, sounds like more of a cya from the superchip than anything, ...I always pull my fuse, ive got it marked with a highliter...glad to here it should,nt mess anything up just in case i forget...errr
Old Mar 22, 2007 | 02:12 AM
drj777's Avatar
drj777
Talking
well - i drove it to work...seemed pretty freekin' good to me!!
WOO HOO!!!
drj
Old Mar 22, 2007 | 03:59 AM
liquid 1's Avatar
liquid 1
sweeeeet is the speedo more correct..
Old Mar 22, 2007 | 01:40 PM
drj777's Avatar
drj777
Talking
seems dead on.
today i might GOOSE up the current program to see how she does.
drj
Old Mar 22, 2007 | 01:51 PM
liquid 1's Avatar
liquid 1
I see you have geared most of your rides, you do it yourself or had it done..
Im going to reprogram for tire size before I move the truck outa the shop and I might need to tune for towing with the stock 3.55 and the 315, WOW she,s going to loook sweet..The DC1 polished rims really set it off..post up on the gooseing, youve got the motor , tuner and the gears it should move on out....!!
