Will a 4.75" backspacing work
Old Mar 21, 2007 | 03:29 PM
coon1976's Avatar
coon1976
I was gonna order my new rims today but figured i better check here first before i shell out big$$$ and have the rims not fit. My truck is a 1996 f-150 4x4 with a 6 inch suspension lift and i am wondering if a 17x9 wheel with a 4.75 inch backspacing will work.
Old Mar 21, 2007 | 03:30 PM
coon1976's Avatar
coon1976
i plan on running 35 x 12.50 tires on this truck with those rims
Old Mar 22, 2007 | 07:04 AM
coon1976's Avatar
coon1976
u mean to tell me that nobody can answer me, come somebody must be able to help
Old Mar 22, 2007 | 10:28 AM
coon1976's Avatar
coon1976
come on somebody must know
Old Mar 22, 2007 | 11:01 AM
MustangGT221's Avatar
MustangGT221
How would we know?
My truck has a 6" lift and 35" tires but I'm running a 15x10" wheel. I don't know what my backspacing is.
To do it right you need to break out the tape measure and straight edge, measure your current backspacing, and figure in what you should have for a backspace on the new wheels.
Old Mar 22, 2007 | 11:09 AM
Lone Wolf #2's Avatar
Lone Wolf #2
With the stock suspension, about the most you can go is 4.5". At that point the tire starts to rub the radius arms, with a lifted suspension unless someone else has used the same lift with the same wheel and tire combo there is no way to say with any certainty if it will work without measuring.
Old Mar 22, 2007 | 11:36 AM
coon1976's Avatar
coon1976
thank you guys at least with that info i am a little more prepared for the outcome and the rims that i am buying are available in 4.5" so i think it will be wise for me to purchase those instead. THANKS!!!
94bonestocker
Sep 13, 2015 01:25 PM
smarty39
Aug 28, 2015 11:26 PM
my1954fordf100
Apr 13, 2015 12:01 PM
nico963
Oct 6, 2009 01:41 PM
