Sponsored by: Real Truck
Steering Box Going?
Old Mar 20, 2007 | 10:53 PM
Stroked Out!'s Avatar
Stroked Out!
Steering Box Going?
HAS ANYONE ELSE HAVE OR HAVING THIER STEERING BOX GO OUT ONLY AT 60000? WHATS THE DEAL IS THAT COVERED?
Old Mar 21, 2007 | 01:29 AM
Cowboy Brett's Avatar
Cowboy Brett
Are you sure it isn't engine oil leaking down from the intercooler duct and onto the steering box?
Do you plow with it? We used to put them in quite a bit on plow trucks back east. Ford's been using the same steering box design for ages.
My guess is that it is a 3/36 warranty sort of thing.
Old Mar 21, 2007 | 09:44 PM
Stroked Out!
I HAD TO ADD STEERING FLUID SO I GUESSED IT Was the box were do i look for the intercooler inlet?
Old Mar 21, 2007 | 11:40 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I took my truck in because it was getting real hard to turn the wheel.
It was diagnosed as a bad/faulty power steering pump. Replaced under warranty, I had purchased an extended Ford ESP when I bought my truck used.
I have not had any issues since.
good luck!
Old Mar 22, 2007 | 02:50 AM
Cowboy Brett
The part on the intercooler I was talking about is on the driver's side, down low and more or less above the steering box. There's a plastic duct that is clamped onto the plastic tank of the intercooler. You can sort of trace it down by following the plastic pipe at that right angle elbow at the front of the engine. It goes down below the air cleaner and then heads over to the outlet on the intercooler.
I could well be totally off base. All I know is that mine looked that way at first and then I looked above it only to find that it was oil from that intercooler duct. Rule of thumb with oil or hydraulic leaks is to look as far above the leak site as you can go and work your way down.
How low was the fluid? If you topped it up, I'd just keep an eye on it and see if it goes down. Usually the steering boxes will fail at the pitman arm shaft seal, which is right there on the bottom of the box.
