Replace door hinge bushings
Old Mar 20, 2007 | 04:15 PM
4rdrules's Avatar
4rdrules
Question Replace door hinge bushings
Simple fix probably, but my hammer and punch wont knock the hinge pin out of the door so i can replace the bushings and fix my sagging doors, any ideas?
Old Mar 20, 2007 | 07:19 PM
Sport45's Avatar
Sport45
Did you saw or grind the flare off the top?
Old Mar 20, 2007 | 09:04 PM
4rdrules's Avatar
4rdrules
nope figured the pin would just fall out the bottom
Old Mar 21, 2007 | 12:42 AM
NavyMIDN08's Avatar
NavyMIDN08
it won't just fall out, especially if its old. check my gallery, i replaced the pins there, i'd recommend just cutting the pin, then knocking out both sides. if you can't get it to knock out, throw some PB blaster on them and grind off the end flares. sometimes, the flares dig into the hinge and kind of wedge themselves in there. i cut mine in the middle, then used a cold chisel to wedge the two sides up, then a pin to drive them out. support the door, or the weight of the door will just add friction and make it even harder
Old Mar 21, 2007 | 09:06 AM
srercrcr's Avatar
srercrcr
Check the latch pin on the body...if it's missing the plastic collar you're doors will sag unnecessarily.
Old Mar 21, 2007 | 10:22 AM
texcan's Avatar
texcan
I did this also but ended up having to remove the part of the hinge bolted to the door to get the bushings out. Made it easier to put the new bushing back in. Then just had to ajust the door after it was back together. I keeped 1 bolt in the door at all times so the nut bracket would not fall out though. Don't know if it would but just in case.
Old Mar 21, 2007 | 02:37 PM
mudgepondexpress's Avatar
mudgepondexpress
Can someone provide me a part number/supplier for the pin and bushings? I have some NAPA Generic ones, but if they are not right, I will be screwed! I would rather spend more $ and have the right ones on hand before I start.
Oh yeah...1981 F150
Kenny
Old Mar 21, 2007 | 04:12 PM
texcan's Avatar
texcan
Got mine at the local parts house for $6.00 a set (1 pin & 2 bushings). Just tell them at the counter what it is to fit and they will look it up for you. I thought they are the same from 80-96 when I got mine.
Old Mar 22, 2007 | 06:40 AM
Sport45's Avatar
Sport45
Mine came from NAPA and worked fine. Just had my son and one of his friends hold the door while I finished knocking the old pins and bushings out.
Old Mar 22, 2007 | 08:41 PM
F3Beam's Avatar
F3Beam
a 3/8" drill bit (Check the size to be sure) works great for removing the flare on the pins.
Old Mar 23, 2007 | 09:06 PM
4rdrules's Avatar
4rdrules
Got them replaced wasnt so bad the second time around. The first attempt resulted in a cracked bushing. A word of advice buy oem replacements if possible, i bought a box of assorted size bushings from the HELP section at advance auto and none of them were the correct size.
Old Mar 23, 2007 | 10:14 PM
mercurycat's Avatar
mercurycat
I looked into changing my bushings, but was able to look through the local junk yard and get 4 good hinges. I have an 82 but was able to use a set from a 90's truck. I believe the Ford replacement is a 90's number.
I ma have some extra as I an finishing up my truck and will not be keeping too many extra parts.
