Sponsored by: Auxito
Abs Light, Egr Flow 99f150
Old Mar 20, 2007 | 03:05 PM
jagee94's Avatar
jagee94
Unhappy Abs Light, Egr Flow 99f150
The Abs Light Comes Every Once And A While, Its On A 99 F150 2wd Base Truck. Any Ideas Why? Also I Have A Check Engine Light With A Code Po401 Egr Flow Insuffient And I Changed The Egr Valve And Still It Comes Back On After I Reset The Light. Any Help Would Be Appreciated.
Thanks
James
Old Mar 20, 2007 | 03:17 PM
KingRanchMan02's Avatar
KingRanchMan02
Do a search on this forum for the P0401. Then do one on the ABS light. Type ABS + light into the search. The ABS light is likely a sensor on top of the rear axle. You will get lots of good reading material on both of these. Good luck!
Old Mar 24, 2007 | 09:27 PM
gramps2plus1's Avatar
gramps2plus1
Thumbs up abs light
ABS sensor is on top of rear axle, most likley faulty. If light on dash bothers you
take the bulb out. I am assuming you still have brakes.
If you have a multi bulb cyclops brake light on back of cab above rear window
you might want to make sure all the bulbs are good. I was told this could be the culprit.
