Dash/Console Lights
Old Mar 20, 2007 | 02:55 PM
ultrikeflyer's Avatar
ultrikeflyer
Post Dash/Console Lights
Hello everyone,
I've searched the forums and could not find the prcedure for disconnecting the dimming feature for the dash/console lights when the parking/headlights are turned on.
Could someone please provide the link for it?
Thanks!
Old Mar 21, 2007 | 07:14 AM
AustinS's Avatar
AustinS
Do you want them bright all the time or off?
Just pull the headlight switch and al your wires are right there. Use a multi meter and determine which wire to snip, and which one to jump over.
5 min. and you're done.
Austin
Old Mar 21, 2007 | 07:27 AM
AustinS's Avatar
AustinS
Sorry, but I think I misunderstood your post. This might help you a little more:
good luck,
Austin
Old Mar 21, 2007 | 07:55 AM
ultrikeflyer
Austin
Austin,
Thank you for the reply.
I would like them to stay bright all of the time. Do you have any idea which wire to snip or disconnect? I'm positive that I had read a thread outlining this procedure here in the formum - just cant find it now.
BTW, thanks for the module diagram on the console plug.
Terry
Old Mar 21, 2007 | 11:14 AM
AustinS's Avatar
AustinS
Found it! Here you go ...
https://www.ford-trucks.com/forums/5...onsole+too+dim
Austin
Old Mar 21, 2007 | 01:19 PM
ultrikeflyer
Thanks AustinS,
Just the ticket! Will perform this procedure this evening.
Thanks again!
Terry
