Help!!!!!
Old Mar 20, 2007 | 02:49 PM
robertr's Avatar
robertr
Help!!!!!
Ok ..... the Toyota Power steering for their 79-84 4x4 pickups is a nifty deal... without question ..... for fitting a decent sized power box into a 48 F1. I'm at that stage on mine right now.
But..... the prices here in the northwest are getting as high as California. $125 to $175 is the deal there, and now here too. The problem is that there are virtually none available in the Spokane area.
Do any on this forum have some good sources of wrecking lots that might be reasonable, and willing to ship?
If the prices have risen everywhere to the level of what I'm seeing here, then something else may have to be used in this steering refit. I can get Saginaw boxes with low mileage for $25, and some work in the drag link mode. It does take more fab work of course, but might just be worth the effort. Guess we in the F1 work have made these boxes pretty high value??
I know that other complete systems for suspension and steering are out there. I even have two different setups in hand, but I'm determined to keep the retro look of the I-beam axle. I know it has its limitations, but old look stuff is my thing, along with a few improvements for modern speeds.
Thanks in advance .....
Bob in Spokane
Old Mar 21, 2007 | 12:40 AM
White_Knuckles's Avatar
White_Knuckles
Pull'n'save or pick'n'pull should have something. Did you try them or spaldings? I usually see Toyota pickups out there when I am getting more "quality" parts for my Ch**y.
Old Mar 21, 2007 | 06:17 AM
AXracer's Avatar
AXracer
www.car-part.com is where I got mine. They have several listed from 50-100.00
Even if you have to buy a rebuilt one at NAPA etc for ~300.00 it's worth it. There are other boxes that could possibly be kludged to work, but no where near as easy and perfect as this one. There are kits to use the saginaw box, but they are much more expensive in the long run, and you'll need a farm field to make a U-turn. Not fun!
Old Mar 21, 2007 | 06:27 AM
bigkid99's Avatar
bigkid99
Try car-part.com. Got mine from a yard in upper michigan, and all for less than $60 shipped. It's heavy remember. Of course, was late last summer so I don't know the current prices
Old Mar 21, 2007 | 10:07 AM
robertr's Avatar
robertr
Thanks Guys!!
I'll check with car-parts.com. And 'White Knuckles' ... I did check with the Spaldings folk in Spokane. A family friend works there and keeps me up to speed on what they have. It's the year issue that is the problem. Lots of later ones are always available .... the earlier stuff is not common now.
Bob in Spokane
Old Mar 21, 2007 | 11:00 AM
AXracer's Avatar
AXracer
make sure you don't put an "s" on car-part.com or you'll end up somewhere you might not want to be.
robertr
Aug 30, 2007 10:52 AM
robertr
May 20, 2007 05:34 AM
robertr
16
May 4, 2007 11:33 PM
robertr
Apr 11, 2004 09:23 AM
robertr
Mar 5, 2004 11:52 AM
