Yippee!!! Finally broke a manifold stud (or two)
I'm not worried about the noise from headers. I don't see anyway I could hear them over my exhaust and the hum of the tires. What is the thread size and length of bolts required for the Banks headers? I want to see about getting a set of ARP S.S. locking header bolts. I'm spending the $$$ so I want to do it right.
Theres a place in the schicago suburbs called LO KO Coating that give a MUCH higher quality ceramic coating then any header company offers now. You send they your mild steel or whatever material header and they dip em and send em bakc out in about a week. May have to wait a couple weeks to get a set in depending on the time of year. But this coating will long long outlast any coating from the header manufacturers. Remember, they are in the buisness of selling headers, if they last forever you wont buy anymore... LoKo has been used by many racers around chicago with great success. If someone is interested i could get you their contact info.
Because the chances of finding used (or cheap) 3-valve manifolds are somewhere between slim and none, I am definitely leaning towards those cheapo stainless headers on eBay.
I can justify it to the wife by saying the stock exhaust manifold on there now has to be milled, and could possibly crack later (which is very true).
So for $200 or so, they have to be at LEAST as good as the 3-valve exhaust manifolds. While the best price I could get on the 3-valve manifolds was somewhere around $400 EACH.
I'm also very tempted to wrap them.
Got the plastic off, shock tower removed, and have pretty much full access to the entire thing (passenger side). Got one or two existing nuts loose (more like the stud abcking out), and stopped there. Tomorrow maybe, I'll continue the deed.
Removing the fender inner is a piece of cake. Removing the shock and it's tower is another two seconds. It's amazing what you can do through the wheel well instead of from the top. Just an observation
Pictures to follow tomorrow ...
Found three total on passenger side broken off, and at least one on the driver's side.
With the amount of milling, and buying studs - and seeing for $200 I can get headers, questionable gaskets and a set of questionable bolts, it's starting to look like a great deal.
With the ease that they can be changed, if I get 2 years out of them, I'll be happy. I'm trying to figure out a way to bend some sheet metal and shield the headers from direct splash, without hindering cooling. Or maybe, sustained temperatures are better than too much fresh air. Would also be nice to heat-shield them from the rest of the (plastic) engine compartment. Might use some stick-on shiny-stuff for the bottom of the heater box.
I have time.
I have time.
#28
#29
The log type manifolds are super easy to get off. The 5 twirling snake tubes of headers are a different beast when it come to getting the proper torque on the bolts. You end up using a assortment of extentions and universals to get to some of them.
The kicker is Banks tell syou to torque them to 18 ftlbs. YEAH RIGHT! Lets see them get a torque wrench in there!
As far as heat shields goes, the banks kit comes with sway bar bushings shields and a starter wrap heat shield. I protected the metal brake line that sits along the frame on the passanger side also.
GOOD LUCK!
#30
