i put 2.5 inch adda leaf on front of my 02 7.3 psd excursion but now i need to lift rear end to keep truck level,especially when i tow work trailer. what are my options without making the truck ride too hard when trailer is not on.thank you.
I just put the Donahoe 2in kit in the front, It sat higher in the front after that. So I just changed the rear blocks to f350 blocks. Now it sits perfect. The ex blocks are the same part # as f250 blocks so this upgrade worked perfect.
Rancho has the RSX shock on sale right now. Buy 3 get one free. I payed $180.00 from summit racing for all of mine. I just replaced the stock shock on my 05 PSD excursion. The old ones only had 26000 miles on them. I noticed a big difference in the ride quality.
will those shocks stll work even though i will be lifting the rear end an extra two inches?i am still using the stock shocks in front with the 2.5 inch add a leaf and they are at their limit,i need to replace them too.should i be looking for f350 shocks or are they the same.thanks for the info.
