1978 - 1996 Big Bronco
Lift for 35
Old May 23, 2002 | 09:46 PM
hoboman22's Avatar
hoboman22
Lift for 35
I have a 89 Bronco that I am planning to put 35/12.5 on pretty soon, what do you guys think would be the best lift for that size tire??
Old May 24, 2002 | 12:02 AM
honney's Avatar
honney
Lift for 35
4"
Old May 24, 2002 | 04:24 AM
cajunbronco's Avatar
cajunbronco
Lift for 35
I'd go 6".The price difference is not that much.With the 4" you might have some clearance problems if you plan to wheel it hard.I don't know what gear your running but if you go to 35's with stock gears it's gonna be a dog.
Billy
Old May 24, 2002 | 04:27 PM
fast_eddy's Avatar
fast_eddy
Lift for 35
I've got a 4" lift with 35s on both of my Broncos, and the tires fit fine. Every now and then I will get some rubbing, so if you plan on doing any serious wheeling, I'd go 6" lift.
Old May 24, 2002 | 06:42 PM
DeGideo's Avatar
DeGideo
Lift for 35
With adding 35" tires,and a 4"or6" suspension lift,I'd suggest 4.10:1 gears(unless your Bronco got them at the factory),or even 4.56:1 gears.Axle code for factory 4.10s is either 25(open),or H5(limited-slip).This info.can be found on your Bronco's data sticker/decal located inside the driver's side door jam.
Old May 24, 2002 | 09:08 PM
honney's Avatar
honney
Lift for 35
ccllud
Apr 16, 2013 09:11 PM
silverf1504x4
1997 - 2003 F150
Apr 24, 2007 07:38 PM
TNT in Round Rock
Feb 10, 2007 04:21 PM
BondoFord
Nov 4, 2005 10:21 PM
4beer4
21
Jun 17, 2004 03:51 PM
