Sponsored by: Auxito
brake help
Old Mar 20, 2007 | 06:47 AM
fourwheelin's Avatar
fourwheelin
brake help
i have a 99 4x4 , last week i had a hop coming from the back of the truck when braking, so i changed the all 4 brakes and the rotors and i bled each wheel about 4 times and i got no air at all, but now my problem is that truck doesnt stop fast, it just kinda glades to a stop and i only have bout a 1/2 of a brake pedal, my thinkin is air in the lines, but i bled them already, is that possible ??? or what about the power assisst going bad, i dont know too much about it ????
Old Mar 20, 2007 | 11:45 AM
Bluegrass 7's Avatar
Bluegrass 7
How did you bleed the brakes?
Best way is to have a helper and bleed into a clear cup with a hose attached to the valve so you can see the air and when it clears.
Keeping the hose in the fluid prevents air from going back in when the pedal pressure is let up.
Bleed till it comes clear clear and air free.
Even a little air in suspension will cause the brakes to be soft. The air compresses, the fluid does not.
Old Mar 20, 2007 | 02:00 PM
7700Rob's Avatar
7700Rob
When you replace pads and rotors, they aren't worn together yet. So they won't give you the best stopping performance until they are properly seated, or worn in. That part will get better, if your pedal is truly low, you may need to look at rebleeding, or if you're just pushing harder to get stopped look into the "wear in" process.
Old Mar 20, 2007 | 09:55 PM
thehawk789's Avatar
thehawk789
soft brake pedals means you need to bleed better. Bleed at the master cylinder and at each caliper/wheel cylinder. Have someone help you, pump up the brake pedal so its hard each time.
Old Mar 20, 2007 | 10:16 PM
Bluegrass 7
Both the previous replies are correct.
You need pad breakin and air out of the system.
Sometimes air can be a problem to get all our since you don't know where it is hanging.
On our sprint car, I get that replayed everytime the system is opened for service and maintaince.
If the air is all out, the brakes are hard as a rock. After some break in, and as long as the pads are right you will have good operation.
I changed from OEM to Titanium pads and got a lot more braking power than I ever had on even the orginal discs. Made the change over due to towing the race trailer.
Just make the effort to get the air out to clear a soft pedal. If the pedal goes to far down, then you may have some other issue to be looked at. If the rear is still drum then it may be the lining is not set close enough to the drums.
Old Mar 26, 2007 | 06:57 AM
fourwheelin
thanx for ur help, it turned out to be more air in the lines, I have never had so much trouble getting all the air out before,
Old Mar 28, 2007 | 11:28 PM
jmjarvis's Avatar
jmjarvis
I think they are all wrong I just did mine an i have the same problem how did you push the brakes apart for the new pads I think some how it screws up the system Me and a friend have had the same thing I think It was from me pushing the fluid back with a C clamp he has a 99 f150 and I have a 2001 F250 Its different than air in the lines!
Old Mar 29, 2007 | 12:20 AM
Bluegrass 7
Well, there is something to be said for pushing fluid back into the lines and master cylinder.
If there is a lot of crud from long contamination buildup laying in the caliper piston bores and lines, it is possible to cause problems even with ABS operation.
Some open the bleed screw before compressing the pistion in order to keep this to a min, then bleed out the rest as much as possible.
Often compressing both front pistons without opening the bleed screws oveflows the master reservior and it runs all over the place. You displace a lot of fluid from the piston bores.
It pays to bleed into a clear cup with a small hose so you can see the contamination, when it clears, when air is no longer coming out and to keep air from going back in the bleed screw before it's closed again.
We do this on a regular basis with race cars. Coming into turns from 125 mph is no time to not to have good brakes, lap after lap.
Old Mar 29, 2007 | 05:34 AM
fourwheelin
well its been about a week now, and i been bleeding the brakes about every other day, and every other day they are good, then every other day they are down again but hopefully now i finally got them. And there are no leaks. I have dun alot of brakes and never in my life had trouble like i have had on this truck !!!!!!!!!
Old Mar 29, 2007 | 05:19 PM
jmjarvis's Avatar
jmjarvis
So say I pushed crud back in to the lines what could I have messed up in the system and how would I go about fixing It Mine are spongy and I never opened the system just pushed the pistons back in so i cant see how there would be air in the lines at all?
Old Mar 29, 2007 | 09:38 PM
PinkyRingz's Avatar
PinkyRingz
the best and the cheapest way to fix all your brake problems is to get a louder horn and an insurance rep that likes you. easy peasy.
