Modular V10 (6.8l)
Trans oil level when hot??
Old Mar 19, 2007 | 10:15 PM
44magnum's Avatar
44magnum
When checking trans fluid the oil does not stick to the dipstick very well and i cant get a accurate read.Does anyone have a cold level? or any other ideas when its hot and running in park. 01 f250 4r100.
Thanks for the info
Old Mar 20, 2007 | 09:18 AM
hydro_37's Avatar
hydro_37
When it is hot clean the dipstick off VERY well and then check it again. You should be at least able to see the "wet line". Use a flashlight if you need to see the difference between the dry and wet dipstick.
Old Mar 20, 2007 | 09:36 AM
exposition's Avatar
exposition
I swab the tube out 1st , then insert the cleaned off dip stick . I have fought this problem until I swabbed out the tube . The tube has fluid splashed up in it & is impossible to read correctly .
Old Mar 20, 2007 | 07:54 PM
44magnum's Avatar
44magnum
Thanks for the swab trick.That is the problem i am having.What tool do you use to swab the tube with.
Old Mar 20, 2007 | 08:59 PM
exposition's Avatar
exposition
A length of welding rod ,super glue a cotton swab on it. DO NOT ALLOW THE SWAB TO GO FARTHER THEN THE DIP TUBE LENGTH! yOU DON,T WANT TO DROP THIS tAMPEX plug into the tranny. I bend a U into the tranny end & crimp it over the swab . A coat hanger will work.
Old Mar 21, 2007 | 09:32 PM
44magnum's Avatar
44magnum
trans oil check
exposition thanks for the swab the tube trick it worked and i was a quart low.
That is what happens when you take it to the stealership!!
