Sponsored by: Real Truck
just curious!!!!!!!
Old Mar 19, 2007 | 06:44 PM
kris-steve0410's Avatar
kris-steve0410
just curious!!!!!!!
wondering what size electric fan or fans i should put on my f 350 7.3 ltr ps,and where a good place to get them from.i am also guessing you just unbolt the fan and clutch assembly right?
Old Mar 19, 2007 | 07:25 PM
99f350sd's Avatar
99f350sd
Why would you mess with someting that works?
Dick
Old Mar 19, 2007 | 09:05 PM
powrstrkn''s Avatar
powrstrkn'
Because you can?
The open diffs in you r truck worked but you put in lockers? why mess with that?
As to the topic , I don't know if anyone on here has electrics, but theres always the innovater?
Old Mar 19, 2007 | 09:11 PM
99f350sd's Avatar
99f350sd
Cause I wanted traction...Your engine will cool better with the stock fan. You might get better ac with elec though. Check flex a lite online...
Dick
Old Mar 19, 2007 | 11:24 PM
6L PWR's Avatar
6L PWR
http://www.flex-a-lite.com/auto/html/ford-diesel.html
As soon as they come out with one for the 6.0L, I'll have it!!
Quoted from their site:
Eliminate the stock belt-driven fan and shroud with the Power Stroke electric fan to improve gas mileage, horsepower, torque and air conditioning temperature.
The new Power Stroke Diesel fan measures 30” x 26” x 4 ½” pulls up to 6000 cubic feet per minute and draws 28-36 amps. Features a fabricated diamond plated aluminum shroud with mounting points made specifically for the radiator. The variable speed control module independently operates the fans from 60% to 100% depending on engine temperature and a/c activation. An optional manual switch (Flex-a-lite #31148) allows the electric fan to be turned off through water crossings. Custom brackets make this a bolt-on installation, and should be limited to GCVW of 18,000 lbs..
Recover 27HP and boost your fuel mileage by 6% just by
eliminating your stock clutch fan assembly
YOUR ABOUT 4 HOURS AWAY FROM BETTER PERFORMANCE
Old Mar 20, 2007 | 07:06 AM
SLE's Avatar
SLE
I'd like to see 27hp, that a good one, almost as good as the tornado & gas saver, LMAO!!!
