1978 - 1996 Big Bronco
Remove propane conversion easy?Hard?$?
Old May 29, 2002 | 11:16 PM
mcrank's Avatar
mcrank
I found a beauty '79 bronco with a 400cid and rancho shocks, the only porblem is that it runs on propane. How hard and expensive is is to make it run on gas? What is involved in the conversion?
Old May 29, 2002 | 11:26 PM
whitebenz's Avatar
whitebenz
Post Remove propane conversion easy?Hard?$?
I once knew a guy who pulled the propane off of his mid-seventies F150. He shortly thereafter burnt some valves. Something to do with propane burning cooler than gas.
That is all I know.
dj
Old May 30, 2002 | 07:47 PM
mcrank's Avatar
mcrank
Strange I was under the impression that a Bronco running on propane was just converted to that using some kind of special kit the might replace the gas carb and mayhbe some other stuff outside the engine. Anyone know anything more about this? Would I have to open up the motor and change some parts?
Old May 31, 2002 | 02:47 AM
whitebenz's Avatar
whitebenz
I don't know for sure. All I know is that his wasn't running and he said it was because he converted it back to propane and that the valves or pistons had burnt in it because the propane burns cooler than the gasoline. Other than what he said I have no clue about it.
dj
Old May 31, 2002 | 12:05 PM
fast_eddy's Avatar
fast_eddy
I have been told that it is a direct conversion. Swap manifold and carb, and your fuel tank, pump and lines and you are good to go. I have a propane 400 sitting in my garage waiting for me to convert it and install it into my '79 Bronco. Hopefully, I don't need any internal parts!
Old May 31, 2002 | 02:08 PM
4xfordman's Avatar
4xfordman
Bootlegger's Deluxe
Alternative Fuels, Hybrids & Mileage
Oct 23, 2017 09:14 PM
PaulsEdge
Jan 9, 2017 07:09 AM
WIKD
Jan 22, 2016 06:58 AM
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 6, 2014 11:27 PM
The_Relic
17
Mar 9, 2012 11:48 PM
