Sponsored by: Real Truck
need help still green!!!!! lol
Old Mar 18, 2007 | 08:46 PM
kris-steve0410's Avatar
kris-steve0410
just spent 1500 dollars to get new upper and lower ball joints on both sides.and a set of new hub bearings on the driver side,alignment and balanced the front tires...okay where do i start, now they passenger side hub seal is leaking not worried about that , that is the dealerships problem since it didnt leak before i took it there.the truck when on the highway arod 75-80 mph shakes really bad...o yeah and truck pulls really hard to the right what could this be...just had the front end job done 2 days ago....o yeah they told me that they couldnt get the hubs off the truck is this a know problem or these guys dont know what they are doing..please help prolly gonna go broke because of this front end..it is a f350 7.3ps with 73,000 miles.
Old Mar 19, 2007 | 05:53 PM
ReAX's Avatar
ReAX
Typically pulling comes from toe-in or brake grab depending on when it happens. I wouldn't expect your tie-rods to be warn out this early, but they could need a little tweaking.
Old Mar 19, 2007 | 06:38 PM
kris-steve0410
okay thanks i will give that a try.
Old Mar 19, 2007 | 06:55 PM
vettdvr's Avatar
vettdvr
I found that they will pull if set with the factory settings. By adding 1 degree of caster to the right wheel this can be corrected if it is pulling to the right and all parts etc are in good shape. Funny thing though Ford sells a special shim/bushing that fits the spindle assembly made to make this adjustment. UMHHHH wonder if they know this truck will pull if set to exact factory specs and decided they would rather make the extra $25.00 for the part. Naw,, never. Jim
Old Mar 19, 2007 | 08:52 PM
boxcar1974's Avatar
boxcar1974
My truck is going in for right side ball joints and front hub lube tomorrow. I have had this left side drift wander for awhile now. I will let you know what they find. I had the left side ball joints done last year. They replace the OEM crappers with moog.
