1978 - 1996 Big Bronco
overheat
Old May 30, 2002 | 07:14 AM
RC Raptor's Avatar
RC Raptor
overheat
I have a 91 302 that over heats only during stop and go traffic. Replaced the thermostat first. Then the water pump. Still to no avail.
I put a lower temperature thermostat in and it ran cooler until... The stop and go traffic during the heat of the day. I replaced the radiator and cap. No leaks. I do have a stout sensor problem according to the code. Any suggestions would greatly be appreciated.
Old May 30, 2002 | 06:11 PM
Flash's Avatar
Flash
overheat
I didn't notice fan clutch on your list which would have been the first thing I would have replaced for stop and go overheating.
Old May 30, 2002 | 10:50 PM
wayne_j's Avatar
wayne_j
overheat
Though the clutch could be going out, if your holding in the normal temp range at 30 mph I would think its okay. If you test the fan and find it in good condiction then I would take the radiator in and have it boiled out. It sounds like the rad might have a blockage in it.
Old May 30, 2002 | 11:16 PM
Pilotrick's Avatar
Pilotrick
overheat
Check the sending unit it could be faulty. Another way to check your temps is put a thermometer in the radiator opening and see what the temps are. If they are close to what your thermostat is then you are okay. Just be sure to take the rad cap of before the motor warms up so you don't have the water explode on you!!!! You can get a thermometer at any parts store for about 3 or 4 dollars and it can also be used to check how cold your a/c is blowing. Something nice to keep in the ole toolbox.
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old May 31, 2002 | 07:11 AM
RC Raptor's Avatar
RC Raptor
overheat
I also replaced the fan with a flex fan and repaced and flushed the radiator. I will check the sending unit next. Thank you!
Old Jun 4, 2002 | 12:25 AM
rikfish's Avatar
rikfish
overheat
I had an overheat problem that drove me nuts......it turned out to be a clogged catalytic converter!
Old Jun 4, 2002 | 11:30 AM
bgblktruk's Avatar
bgblktruk
overheat
tomwhatley
42
Dec 9, 2014 10:55 PM
99ExpyProblems
Oct 1, 2013 02:58 PM
kc7nwi
1983 - 2012 Ranger & B-Series
Dec 11, 2012 12:26 AM
Big Red
Oct 10, 2004 06:45 PM
robv60
Oct 8, 2004 04:02 PM
