MPG as an indicator of engine health
I have spent several of my past weekends catching up on those little things I've neglected for many years. The old girl ('93 Aero 3.0L) has been faithful and I owe her some attention...
New IAC, O2 sensor, PCV, tranny filter, tranny gentle flush, Hayden tranny cooler, exhaust parts, Seafoam treatment in gas tank (20 gals - 2 cans), Seafoam treatment in oil pan (100 miles, then oil change). I've bought the spark plugs, distributor cap, rotor, and plug wire set for this weekend's task.
BUT, with all the work I've done to date, my miles per gallon has gone from 18 MPG to 26.2 MPG (at constant 70 mph highway). I get no OBD I codes or operating weirdness indicating anything else needs attention.
I have owned this Aero since mile #1 and to be honest, have not treated her well until now. So, I can't tell you (memory not so good) if I have EVER changed the plugs/wires/distributor in the past 201K miles. I have always approached car preventive maintenance with the "if it ain't broke, don't fix it" mentality. Is it time for this old guy to change his evil Aero ways??
Thanks,
Michael
'93 Aero 3.0L
'94 Aero 4.0L
Thanks,
Michael
'93 Aero 3.0L
'94 Aero 4.0L
I think i might have to follow your lead, i bought my 91 RWD 3.0 auto with 263,000 k, it now has 326,000 k, from a colleague at work, he serviced it religously, i just changed to "if it ain't broke don't fix it " i'll get another 100,000 k & toss it attitude.
But in retrospect, its slowly falling apart & i know most things can be fixed if i just put a little sweat into it, for example;
-the driver-side window stopped working in the fully up position just b4 winter set in (changed both motorized switches 3 times) drivers motor finally crapped out !
dash lights stopped working 1 yr ago ! (tore dash apart 3 times & checked with vom)-looked at several possibilities & gave up (i drive mostly during the day) why bother LOL!
-running on synthetic since i took it over, - it had a knock (mild tho it be) at start-up, so i thot this prudent to save metal ware on start-up
-every fluid is leaking or being consumed
-i changed roters & pads upfront only to change the caliper near xmas cause both (if not all 4 brake pistons are leaking)- OH by the way-i have dash lights (warning indicators dash lights LOL !, "Brake & rear-antilock" "high-beams"-cause i was to lazy to rip the rear bumper off to change the front sealed Beams LAUGH if you like ,you know what i'm talking about! - so i just re-aimed the lights & run the highs (its always the lows that burn out-go figure!)
i could go on about other things, for now they escape my memory
Michael
91 AERO 3.0L RWD
Michael
91 AERO 3.0L RWD
Michael
91 AERO 3.0L RWD
Michael
91 AERO 3.0L RWD
Whats that about ripping off the rear bumper to get at the high beams ????
Anyhow, she deserves a bit of TLC, .... go for it
Thanks,
Michael
'93 Aero 3.0L
'94 Aero 4.0L
Thanks,
Michael
'93 Aero 3.0L
'94 Aero 4.0L
Would you say the Seafoam treatment had any effect on your fuel economy? I might try that since it seems to be well recommended.
All the best, Aeroman.
I got a pretty consistent 20-21 MPG in the '89 shorty (4.10:1 rear). In the glovebox of the '93, I just found the original sales papers (sold for $21k in 1993) and window sticker, with the EPA rating of 17/23 MPG City/Highway (3.0l, 3.73:1 rear).
Seems like in some long-ago MPG thread, the folks with the 4.0l were getting better mileage on average.
My $.02. There's a balance between "if it ain't broke, don't fix it" and the urge to "improve" performance. I thought my then-new Bosch Platinum plugs would enhance my Aero. Instead, after spending more time and money with cleaning the MAF, Seafoaming the engine etc, I've learned that the new plugs must have been the culprit of all my pinging on regular fuel.
With the Autolite Double Plats recommended on the forum, I can run 87 octane again without the dangerous pinging that forced me to 89 octane. That will pay for itself soon.
Moral of the story: It's good to be a pioneer now and then but don't over do it. Listen to the sages that have been down that road before and at least do the recommended maintenance or poor performance will creep up on you.
Thanks for the feedback
Thanks guys, your advice/recommendations are always on target.
I will go ahead and change the plugs, wires, and distro cap/rotor this weekend...since I already purchased these parts. Also, I can't stop that nagging feeling that 201K miles is long enough on these orginal plugs, wires, and rotor...
Michael
'93 Aero 3.0L 2WD Ext
'94 Aero 4.0L 2WD Ext
Michael
well; i can't says i know what my fuel milage is, but if i hazard a guess, i'd say 17-23 mpg is about right> less for the in city actually esp. in winter !
anyone know how big the tank in a 3.0 liter auto 91 ext is ? it's been a while since i filled it all the way up !
i think i have 3.73 : 1 rearend ratio & i kinda like the rear anti-lock, but i'd never go antilock all the way, i nearly piled up a older ford extended i borrowed , i came within 6 inchs of someone else's back bumper at an intersection - thinking i was driving my old tempo!
Oh-- & about taking off the rear bumper to change headlights, i was only JOKING, but i striped the phillips head screws & work-hardened them trying to drill them out, so now in order to change them i need to pull the grill & flex & pull the bezel's & unplug & twist the inner plastic shrowd & twist & pull the headlight out, - - oh & make sure its unplugged b4 you do all that & test the headlight b4 you put it all back together , sware & argue with yourself lots , all while holding a flashlight in your mouth so you can line up those hard to reach screws that you keep dropping "Whew"
Michael
'91 Aero 3.0L RWD Ext
Michael
