hi yall. i have a 2001 f-250sd automatic, and just cant understand why it shifts kinda sluggish, any one prefere a specific shift kit and transmition fluid cooler . any reply would be nice
How about some maitenance?
Change the fuel filter,clean the maf ,reset the computer !
Also service the tranny /filter /fluid and chk your brakes and diff fluids.
This is the part you will need, if you have a gas motor. To install, ubolt the trans pan, take out a dozen bolts and two nuts, slide the orignal valve body off the studs and push the new one on. It's an hour install if you rush it, but 1.5hrs taking your time and enjoying the job.
