1990 Ford Ranger
Old Mar 17, 2007 | 02:54 PM
maier1205's Avatar
maier1205
1990 Ford Ranger
Hi, we need help. Our brake lights will not work on our 1990 Ranger. We have changed the bulbs, fuses, brake switch and flasher switch. We have checked the wiring but still can not get power to the brake lights. All other lights work. Any ideas on what else we can check or do?
Old Mar 17, 2007 | 03:45 PM
F150 hybred's Avatar
F150 hybred
Is it possible that you have a problem with the connector located on the frame at the rear of the box? Possibly a ground problem?
Old Mar 17, 2007 | 08:21 PM
michigan66's Avatar
michigan66
Do your tail lights work? That includes the license plate lights. If not, check the electrical connector underneath the bed at the left rear corner - it could be corroded or coming apart.
Old Mar 18, 2007 | 05:28 AM
fflintstone's Avatar
fflintstone
Very common. But, your brake light and running light share a common bulb, do they not? Double filament bulb. #1-Did you change your bulb with the right bulb? #2-Trace the lead back to the each connector in the wireing until you find a 12V reading with the brake pedal depressed.
If it's a double filament bulb, the ground is obviously ok because the other filament lights up. For tracing the hot lead back to the brake pedal switch, you'll need a wiring diagram so that you can see which pin in each connector is for the brake lights.
Before you get into that, find, disconnect and clean all connectors in the harness.
Strychnine08
37
Dec 2, 2016 05:21 PM
Bigbeth
50
Oct 20, 2014 08:03 PM
Greywolf
Tennessee Chapter
May 19, 2006 05:36 PM
ClydesdaleCowgrl
Oct 24, 2004 01:41 PM
bhenderson
Electrical Systems/Wiring
Nov 13, 2003 07:11 PM
