switching fuels
Old Mar 16, 2007 | 10:15 PM
All Things Oval's Avatar
All Things Oval
switching fuels
I have a stationary inline 6 engine running on natural gas and want to switch it to propane. Will the natural gas system run propane? The intake manifold is upside down, and the exhaust is straight upward. Can a propane carb still operate if the carb and other components are flipped upside down? What mods are required to do the switch?
Old Mar 17, 2007 | 03:06 AM
WarWagon's Avatar
WarWagon
A propane carb will operate upside down. You will need a propane mixer, converter and fuel lockoff......................and a tank of propane, of course.
Old Mar 17, 2007 | 10:46 AM
LxMan1's Avatar
LxMan1
It may need to be rejetted. I know a furnace uses different orfice sizes for natural gas and propane.
Old Mar 22, 2007 | 09:16 PM
gasman6674's Avatar
gasman6674
Depending on the equipment maybe. If its IMPCO you may or may not need to put in a new air valve/diaphragm in the carb but you will need a regulator to put in the supply line as the Nat unit will not work. Contact your LP supplier and ask them to research it for you.
Or e-mail me and I will give you my 800 number
Regards
Gasman
Opossum
Alternative Fuels, Hybrids & Mileage
Sep 20, 2012 05:53 PM
TaborCT
15
Sep 3, 2011 07:04 AM
fishindave11
Jun 26, 2008 01:18 PM
FreakinOldGuy
Oct 12, 2006 10:10 PM
trev400
Jan 17, 2005 01:00 AM
