Opinion on Ceramic coated headers?
Old Mar 16, 2007 | 04:18 PM
CN Spots's Avatar
CN Spots
Any opinion, good or bad, on ceramic coated headers? I've found a nice set for under $300 and figured I'd bling up my 390. Is the coating durable? Are they a pain to keep looking nice? If I buy them, will scantly clad babes flock near my truck as indicated in their ad? Please hep!
Thanks,
spots
Old Mar 16, 2007 | 07:18 PM
weeds's Avatar
weeds
Buddy of mine has Hooker ceramic coated headers. The ceramic coating is starting to flake after about 3 yrs of having them on, but there's no signs of any rust or anything on the metal.
And yes, scantily clad babes will flock to your truck. But be warned, you might not want ALL of them to be scantily clad.
Old Mar 16, 2007 | 07:45 PM
wrobo23's Avatar
wrobo23
for $300 i'll throw the headers in the cab and the girls in the bed!
Old Mar 16, 2007 | 08:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
Ceramic is the best thing since sliced bread as far as the local rod shops are concerned.
Old Mar 17, 2007 | 01:25 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
If your starting out with new headers with high end not cheapo's I would check for fit then smooth everything then have them ceramic coated inside and out not just the outside. It does make a difference especially if done all the way back to and including the X cross plus good high flowing exhaust system and mufflers.
Your FE will thank you.
Old Mar 18, 2007 | 12:47 PM
dkf's Avatar
dkf
I bought a set of Dynomax ceramic coated headers for my 74' F-100 302 and the were rusted after about 2 years or so. These header weren't expensive but I have lost faith in ceramic coating for a rust inhibitor. IMO the only way to go is with stainless if you want the headers to last and stay nice. My next set for the 74' will probably be painted cause to keep the cost down. Then when they rust I'll pull them off and repaint them.
Old Mar 18, 2007 | 01:44 PM
"Beemer Nut"
Ceramic coatings are only as good as the person who applies them and being they were on a lowest bid contract from the header manufacture this is what you get.
Coated in and out by HPC i've never had a rust out or even a rust problem with many years use.
Hence raw headers, check fit, blend, smooth down sharp edges then have coated and enjoy.
Old Mar 19, 2007 | 07:56 AM
CN Spots's Avatar
CN Spots
Thanks Guys!
spots
Old Mar 20, 2007 | 10:29 PM
Stroker4Life's Avatar
Stroker4Life
I sent my L&L headers off of my 429 to Jet Hot Coating Inc. about 4 years ago. Don't have alot of miles on them, but they still look great. No rust or flakes, but a slight fade i would say. They are coated inside and out. Look pretty sweet sticking out of the fenderwell!!!!!!
Old Mar 20, 2007 | 10:31 PM
Stroker4Life
Also I forgot to mention. If the headers you are going to buy are good quality and worth putting on your FE then jump on them. Just to get my headers shipped and coated was about $380...not to mention the L&L headers are around $400+ a set now days.
Old Mar 26, 2007 | 01:14 PM
CN Spots's Avatar
CN Spots
I wound up buying the next better set from Heddman. They're thermal coated, not as shiny, but are made better than my first pick plus they have ball and socket connectors. Can't wait to slap 'em on! Thanks again!
spots
