Dp-tunes
Old Mar 16, 2007 | 10:36 AM
hdman6's Avatar
hdman6
Question Dp-tunes
I have the dp-tunes setup as no start, stock, 60 tow, 80 econo, 120 race. I installed the bts valve body that jody reccommended and all the other upgrades needed. My question is this.. I thought there would be more smoke when i was on the 80 or 120 setting. I dont get hardly any smoke compared to what other guys here are talking about. Also if I run the stock tune the shifting is hard, will that hurt anything in the tranny since it is set up with the BTS for the 80 econo. There is a big difference in the shifting from the stock tune to the 60, 80, 120 tunes. the programmed tunes shif very smooth. One more question, I have to take the truck in to get looked at for another problem and was wondering if they hook up the code reader, as long as it is on the stock tune will it read the same as if there was not tuner installed at all? thanks jeff
Old Mar 17, 2007 | 04:28 AM
jtharvey's Avatar
jtharvey
I don't know why you're not getting a lot of smoke...perhaps you have a good turbo that clears it up. I typically just have a haze on the 100 and 120 settings, with the 80 setting hardly smoking at all.
The harder shifting in stock mode won't hurt anything.
With the tuner on stock setting, yes it will read codes just like normal.
Old Mar 17, 2007 | 06:27 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
With my lower end DI tunes I don't get a lot of smoke either. 120 and above she will will pour it out. DP is probably the same.
Old Mar 17, 2007 | 07:17 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
with 120 i dont get smoke this toon is not ment to smoke , more smoke more hp out the window, get the 140 extreme and you will see smoke gashing out
and like JT said i only get a haze when i get on it in 120
Old Mar 17, 2007 | 11:42 AM
hdman6's Avatar
hdman6
Smile
so if I sent my dp tuner back and got the 140 extreme tune added it would gush out smoke right? Would that really be pushing the limits of the truck ? I dont want to prematurely ruin anything either I was just hoping I could get a smoker tune to ward off the bugs once in a while when they get to close (lol) jeff
Old Mar 17, 2007 | 12:14 PM
PETE'S_6.0PSD
Jeff, with your stock system you wont be Gashing out smoke for sure, it will be moderate amounts, nice to give somone bihind you a good caugh from Sud LOL
im doing stage3 injectors H2E turbo and regulated return, that should produce Huge amounts of smoke in low end and nice HP
Old Mar 17, 2007 | 02:08 PM
hdman6's Avatar
hdman6
Thumbs up
thanks, thats what i was wondering about. I really dont want to go too deep on mods just to spit out wasted fuel for some smoke. I can live with what i got (for now). thanks for the input jeff
dothedew192
Dec 2, 2015 10:46 AM
darknight
53
Sep 1, 2015 09:05 AM
ReugularGuyBob
13
Jun 6, 2015 03:53 PM
hotrodtodd
Oct 9, 2014 05:35 AM
DIYMechanic
58
Nov 23, 2013 11:28 AM
