push is gone
Old 03-15-2007, 09:03 PM
4wdriver's Avatar
4wdriver
4wdriver is offline
push is gone
my 05 regcab had a bad understeer condition since new.well its gone, not sure if its the new tires or new z code front springs,but it turns much better so far.i posted a couple days ago that ford was replacing my tires due to unevenly worn tread.its one of the tsb's, i had hankooks they were awful.well they found more hankooks so i traded them to a local tire place and got the tires i wanted for 200 bucks mounted and balanced.the springs were installed today also the labor was $88.00 .
Old 03-15-2007, 11:29 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
Chances are your alignment was off. Toe-out on turns is a major contributor to Over/Understeer. If your alignment was off, it will not only wear tires but cause these conditions. You had it aligned correct??
Old 03-16-2007, 06:12 AM
4wdriver's Avatar
4wdriver
4wdriver is offline
they gave me some line about try it see how it is when i asked about the alignment.i will get it done this weekend somewhere else i can trust.
Old 03-16-2007, 06:41 AM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
When the dealer replaced the Hankooks they also did an alignment. That is the primary purpose of the TSB. By changing springs and tires I would definitely get the alignment checked again.
