boost tube installed
Old Mar 15, 2007 | 08:02 PM
bigtorque's Avatar
bigtorque
well, reinstalled my boost tube, and now the the roads are dry, i noticed a huge difference today, maybe the moons were in line or something.
so, im getting on the highway in stock tune, (currently 9 deg).
engine at good temp. so i start to merge and a newer chevy wont let me in.
so now the peddle is on the floor and i make enough room to squeeze in front of him and hes on my ***, so i keep it to the floor and i distance myself, but when i looked down @ 100 mph, 800 deg and 25 psi in a stock tune. i about shat myself, i hadnt been that high in the stock setting before, i even double checked the setting, i couldnt believe it, the most i had seen in stock was 22 psi. and 65 mph to 100 took maybe 10 seconds or so,
any way.............so, any one ever seen 25 in stock setting, if so, boost tube increase at WOT is approx. 3 psi.
Old Mar 15, 2007 | 08:27 PM
Uzumati's Avatar
Uzumati
Thats about where mine was but it killed the fuel mileage so bad it is still sitting in the glove box.
Old Mar 15, 2007 | 08:34 PM
bigtorque's Avatar
bigtorque
i havent noticed any fuel mileage difference, im getting 10 with and without tube.
with lots of warm up time being as i havent seen temps over 20 in a couple months. been one cold azz winter.
and i was gettin 15 mpg this past summer daily driven in town. before all the mods. so im hoping i will see a big mpg. increase this summer once the fuel changes and the weather warms up.
Old Mar 15, 2007 | 08:37 PM
Uzumati's Avatar
Uzumati
Thats what I am waiting on to put it back on and do some testing. Once summer blend gets in good and mileage stabilizes after everything i did this winter.
Old Mar 16, 2007 | 09:52 PM
dfuser's Avatar
dfuser
what kills mileage is a heavy foot!
Old Mar 16, 2007 | 10:52 PM
ernesteugene's Avatar
ernesteugene
I'm pretty sure that mpg decreases because the MAP sensor can't see the full boost being developed under some conditions, and the PCM schedules more fuel trying to get the boost up to where it thinks it should be for the given load on the engine. Kind of the reverse of de-fueling when the PCM thinks boost is too high for given conditions.
This is what Banks told me when I visited there awhile back. They were providing their customers with a zener diode "fix", to clamp to voltage to the MAP sensor to avoid SES due to over boost, but got so many reports of reduced mileage they stopped using that approach.
Old Mar 17, 2007 | 06:46 AM
dfuser's Avatar
dfuser
Nope, Not it!
What do you think a driver is doing when they know they can run 25+ lbs of boost? They are driving their Engine hard...Which leads to low mpg.
I can tell you by adding the Boost tube and either the Dual Relief Valve or MAP Mazimizer that we offer, you will NOT loose MPG if you drive normally and not like you stole it. The combination allow you to add more air, which should help the Engine run cooler and more effiecent. Less black smoke which means you are burning the fuel and not wasting it.
Old Mar 17, 2007 | 07:44 AM
Uzumati's Avatar
Uzumati
Ernest the boost tube doesn't effect the MAP it only holds the waistegate closed a bit longer allowing more boost on the top end but the PCM will still defuel at 24psi.
dfuser - I think you are on to the root of the problem here, with the boost tube i did see 17-20 psi more often than the 10-13psi i saw without it, but I have traced mileage issues to a faulty MAP on my truck.
Old Mar 17, 2007 | 11:06 AM
ernesteugene
Do you have a ref for this boost tube so I can see what its doing. I remember the old Superchip "boost tube" idea of bleeding off a calibrated amount in the line to the MAP, also the various relief valves in this line, and the diode approach, all of which are intended to fool the PCM by not letting the MAP see the true boost. All of these approaches reduce mpg for the reason I've stated. Talk to Douglas, his Ford specialty shop in Atlanta, GA he found the same effect with the diode approach and stopped using it.
Old Mar 17, 2007 | 12:39 PM
dfuser's Avatar
dfuser
Well I do not use the diode approach. I get 17-20 mpg with the boost tube and Dual Relief Valve Both Installed.
The boost tube delays the openning of the waste gate to allow more Boost
The Dual Relief Valve allows the MAP to see amx of 22-24 lbs of boost and that is only when boost is over 22 lbs.
With both installed your MAP signal is not altered.
So I am not sure how you can loose MPG unless you are driving your engine hard!
Old Mar 17, 2007 | 12:41 PM
Uzumati's Avatar
Uzumati
Its on Pure diesel power or dfusers web site.
It connects between the red line and the waistegate actuator and bleeds off about 1.5 psi of waistegate control pressure.
The WG solenoid regulates between 5 and 8 psi of pressure to the actuator through the red line, the waistegate starts to open at 5 psi and is fully open at 8 psi (regulated pressure not boost pressure). The solenoid uses the green line to dump pressure back to the intake when no actuation of the waistegate is required.
Old Mar 17, 2007 | 02:34 PM
billfishnut's Avatar
billfishnut
Why not just unplug the waiste gate actuator? I've heard people say they do it and tried it myself. I saw no real changes so I plugged it back in. If less pressure (on the actuator) means more power than theoretically, no pressure should be max power.
Old Mar 17, 2007 | 04:55 PM
ernesteugene
My wastegate control system!
My plug-in 70 HP Superchip disables all PCM control of the wastegate actuator. My boost would typically run at 26-28 psi for miles on end while pulling grades. After wearing my turbo bearing out at 50K miles, I decided to take it a little easier on the replacement turbo so I came up with this scheme for doing so, Click for full size image
I now adjust my maximum boost by using a second spring in compression that works against the stock spring to reduce its tension. I guessed on the initial amount of compression, and clamped one end in place on the actuator rod, and the other end butts against the actuator housing. Through trial and error, I kept inserting slotted washers to increase the compression until I got just the right amount of overall tension to limit my maximum boost to 20-22 psi when towing up a grade.
Old Mar 17, 2007 | 05:22 PM
ernesteugene
Yes, the PCM pulses the solenoid to control the actuator, and it's a so-called "bang-bang" feedback control system. Bang, solenoid is wide open, and bang, its shut! The PCM is trying to adjust the wastegate by varying the duty cycle of the bangs until it sees the MAP reading that it expects to see for the given engine load. Bleeding off 1.5 psi will just make the PCM increase this duty cycle in an attempt to regain control. At least that's what I was taught about feedback control systems, but then that was more than 45 years ago.
Old Mar 17, 2007 | 05:39 PM
ernesteugene
Well, I think the MAP signal is altered, and here's why. The relief valve is spring loaded, and in order to be open far enough at 22 psi to bleed off enough boost to avoid a SES, it starts to open and bleed some boost while the boost is still less than 20 psi, and this means that the MAP never sees the maximum boost reading that it does without the valve.
BTW, I have one of these valves (don't know if it's your brand because it in storage) and I've measured the above effect on mine using an air compressor with a regulator and a gauge! Any one that wants mine can have it for free, just send a PM.
