Junk 302 Or What?
Old Mar 15, 2007 | 02:13 PM
F250Tech's Avatar
F250Tech
Junk 302 Or What?
I Have A 89 F250 4x4. Has 302 That Does Not Run On #2 Cyl. Have Checked Firing Order Several Times, Have Changerd Distribitor, Have Changed Injector, Have Removed Valve Cover And Checked Pushrods And Rockers, Have Did Compression Test 90lbs., Any Help Out There Or What. Open Tp Suggestions.
HAVE ALSO CHECK INJECTOR PULSE, CHANGED UPPER PLENIUM
Old Mar 15, 2007 | 06:20 PM
subford's Avatar
subford
Change spark plug, spark plug wire and distributor cap. Look at it at night while it is running for cross-firing (arcing).
Old Mar 15, 2007 | 06:25 PM
Kemicalburns's Avatar
Kemicalburns
if it has only 90lbs then yes its shot. time for a rebuild or 5.8 swap
Old Mar 15, 2007 | 06:28 PM
cypress_33415's Avatar
cypress_33415
At what lbs should the cylinders be???
Old Mar 15, 2007 | 10:55 PM
toddol1971's Avatar
toddol1971
125 to 150
Old Mar 17, 2007 | 04:07 AM
albung's Avatar
albung
put oil in plug hole and retry if goes up rings leaking if not valve not seating
