Bad IAC valve?
Old Mar 15, 2007 | 01:44 PM
nighthawk285's Avatar
nighthawk285
Bad IAC valve?
I have a 1987 F150 that I did a 351 swap into. Its from a 1994 Bronco, and the ECM for it is from a 1989 F250(finding parts are fun). There is a bit of an idle problem, but I'm not sure what it could be.
At first start up, it shoots up to 1400, then comes down gradually to 1000, when I start driving, its fine until I have to put in the clutch....
Then, it does one of two things, it either,
Revs up to 2000
OR
Idles down to 1200 for the shift
Both seem to be at random for which one it does, doesnt matter if the engine is hot or cold.
Another thing is that when it does eventually idle down, it hits 700 and stays there for a few seconds, then the idle dies down to about 550 or so and starts getting really lopey.
I thought IAC valve, but it's not throwing any codes, in fact, nothing is, does that matter? Thanks in advance for any ideas
Old Mar 15, 2007 | 01:48 PM
quicklook2's Avatar
quicklook2
replace iac.
Old Mar 15, 2007 | 01:49 PM
nighthawk285
ok, do I need the one for the 94 engine, or the 89 ECU?
Old Mar 15, 2007 | 10:57 PM
toddol1971's Avatar
toddol1971
call napa & ask if its the same one. It probably is.
Old Mar 15, 2007 | 11:30 PM
nighthawk285
its not though, and the one for the '94 has two different models, so do I just order the one with the same OEM number?
Old Mar 15, 2007 | 11:34 PM
Trickedout420's Avatar
Trickedout420
just clean it?
Old Mar 16, 2007 | 12:27 AM
nighthawk285
tried that, but still the same result
Old Mar 16, 2007 | 12:30 PM
nighthawk285
well I ordered the one for the 89 to match the comp, as the throttle body mount looked the same....will let you guys know how it goes
Old Mar 16, 2007 | 01:31 PM
quicklook2's Avatar
quicklook2
that would have been my choice.
chris3075
1983 - 2012 Ranger & B-Series
Feb 13, 2013 08:49 PM
Ruger6
May 21, 2012 04:31 AM
SteveO.
Jan 4, 2012 01:49 PM
JFlom77
Feb 23, 2010 01:00 AM
quisp-n-quake
Sep 25, 2007 09:24 PM
