Sponsored by: Real Truck
Front pinion nut
Old Mar 15, 2007 | 11:53 AM
dadsgreenpsd's Avatar
dadsgreenpsd
Front pinion nut
I noticed a minor leak at the pinion seal last fall (running in 2wd), and I kind of forgot about it until recently. I heard a minor clakity clack, so I crawled under the truck, and noticed the driveshaft was a bit loose. No big deal, u-joint, right? Actually, the nut holding the yoke to the pinion shaft is loose. Well, I guess I could just crawl under there and tighten it, but was wondering if i should replace the yoke, or clean and apply loctite to the splines, etc. What else am I going to find under there? Hmmmm... I ran in 2wd all winter, and now that it is springtime, i am needing 4wd to get in and out my road for the next coupla weeks.....
Thanks all, and happy spring!
Old Mar 15, 2007 | 12:04 PM
redford's Avatar
redford
FTE Leadership Emeritus
I would tighten it, replace the fluid and just keep an eye on it for now.
Old Mar 15, 2007 | 12:06 PM
F250Wheels's Avatar
F250Wheels
That nut that holds the yoke also sets the pinion bearing preload, you can not just tighten it real tight. Infact once that nut is backed off you are suppost to install A new cruch sleave and reset preload.
Old Mar 15, 2007 | 06:17 PM
04F-250 stroked's Avatar
04F-250 stroked
Thats what i heard also!^^^^^^
Old Mar 15, 2007 | 07:39 PM
dadsgreenpsd
OK, so i need a new crush sleeve, and seal, of course. At what point does the yoke become unusable?
Torque for nut? loctite maybe on the splines? on the nut?
Thanks!
Old Mar 18, 2007 | 02:16 AM
johnjk's Avatar
johnjk
Loctite the pinion nut, not the splines. Also, get a new nut. Most are designed to go on only once.
The yoke should be fine. Remove front axle shafts (far enough to get the carrier out), remove carrier, remove pinion, install new crush sleeve (you may want to consider new pinion bearings) torque pinion nut until you begin crushing the sleeve then go real slow until you get about 15 in. lbs of preload. This is an approx. number for used bearings, I'm not sure what the exact spec. is for a Dana 50. If you exceed the top end of the spec. you will have to install a new crush sleeve and pinion nut and start over. Also, you will need an in. lbs. dial torque wrench to measure pinion preload.
I've built a few diffs. and installed some lockers, but I'm by no means a diff. expert, so don't necessarily take this as the gospel.
Also, above is the "correct" way to do it. You may want to try loctiting the nut and tightening it up to about 150 ft. lbs. If you do take this short cut, you risk not having the correct pinion bearing preload, which if left unchecked could possibly destroy most of the front diff.
Good luck, and hollar if you have any more questions.
Oh yeah, don't forget to install the new seal too. I left that out.
