Passenger side door panel
Old Mar 15, 2007 | 03:05 AM
tommyleea's Avatar
tommyleea
Good Morning..I am replacing the passenger side outside mirror, so I need to remove the door panel. I removed the screw behind the triangle panel, the one in the courtesy light, and the door handle. Now, I popped out the power window control panel, and there is a screw that is accessable thru this opening. I believe this screw has to be removed, but it is frozen in place. It doesn't have the hex head, so all I can use is a screwdriver. I used the impact screwdriver, but to no avail. I cannot believe this screw can be in that tight. It is a 99 Expy, and there is no rust. Has anyone experienced this before? Any tips? I don't want to destroy the screw head. Thanks..
Tommy
Old Mar 15, 2007 | 02:38 PM
leos7273's Avatar
leos7273
Yes, this screw has to be removed...mine was pretty easy to come out.
Did you use just the impact screwdriver or a regular screwdriver too?
