i just bought my 9 ford truck since i have been 16 (now 30) and it is my first four wheel drive truck it is a 79 f250 4x4 with a 400cid engine and a c-6. I have not got to drive it yet because it need a couple new u-joints at the wheel this sucks i am really looking forward to this new 4 wheel drive stuff can anyone tell me if there are any good 4 whelling parks in northern illinois or close by
No clue about places for you to wheel, but just wanted to say congrats, that's the same truck I'm running (which it so happens is also my first 4x4)
You might want to try asking around in the Off Road Forum, or the Illinois Chapter. Welcome to FTE!
Excellent! Replace those u-joints. I always just bought Spicer u-joints, places like broncograveyard.com have them. Napa u-joints seem good as well. Go through the whole truck, you won't regret it. Start at an area, such as the driveline, check things, like you have already: u-joints, slip joint, rear end play, front end play, hubs, wheel bearings, brakes, emergency brake cables. This area is crucial and you mine as well start off on the right foot, knowing how your truck stands. Chances are, if u-joints are shot, other areas of your driveline are worn as well as your suspension (ball joints, tie rods, bushings, etc)
From your description, it sounds like you need axle joints?. Try and get the Spicer brand joints, you can't go wrong with them. They even make them now with zerk fittings so you can grease them. This will also provide you the opportunity to re-pack/replace the wheel bearings and seals, and check the brakes. Good luck!
