Radiator fluid in oil
when draining my oil out it was coffee cream colored. engine has 50k on it. never ran it on low oil. oil pan has a hole in it. so no oil has been in it for months. when i moved it, 1/2 block put 4qts of oil in it. when drained it that was that color. am i looking at a new gasket(s)? And is that gonna run me 2k? thanks for any help!!
ahhh, hold on, be very careful! It is probably coolant getting in there. If you start it and warm it up, which i would probably not do, pay very close attention to it. You could run the risk of destroying your engine. Right now, you can save it by not starting it, taking a step back, closely examining what is going on, and doing some research by making phone calls to the dealership and/or your local mechanic. This is just my opinion though, i tend to get paranoid with this stuff. Do you have the 4.2L V6? Apparently, those have bad intake manifold gaskets that let coolant into your engine (not good). I am in the same boat. Currently, I am going to park mine (97 f150 4.2L) and replace the gasket myself. Even though my oil looks fine and everything seems ok, I am still going to replace it to be on the safe side. Again though, I may be wrong with your situation, but from what you said, it sounds like a possible major problem so use caution and if in doubt, just dont. Good luck.
mrad
07-04-2014 12:44 AM
