f350 front end pull
Old Mar 14, 2007 | 11:21 AM
auctioneer46's Avatar
auctioneer46
f350 front end pull
Hi guys,
I'm confused about the front end of my 95, gas, f350. It pulls toward which ever direction I last turned toward. If I turned left it pulls to the left when I straighten out and vice verse. Everything seems tight under there except the tracking arm has just a tiny bit of play. Any ideas?
Thanks,
Adam
Old Mar 14, 2007 | 11:39 AM
Josh88Ford's Avatar
Josh88Ford
Sounds a lot like bad balljoints. go in front of your truck about 20 feet and see if your tires are sitting like /---\(when last driven in forward, not reverse) It might be hard to see with a solid front axle. Another way is to jack your front end up, grab the bottom of the tire and pull it forward. There theres play doing that, its bad balljoints.
What your encountering is called "memory steer" which is due to old ball joints.
Unless your HARDCORE mudding, I would go with Moog ball joints. Best I have heard, and have had mine in my ttb with 33's for about 20,000 miles so far. If not, make sure you get greasable balljoints
Old Mar 15, 2007 | 05:43 PM
auctioneer46
Thanks Josh, I was thinkin' that might be it. Just wanted to hear it from someone else before I spent the money and time on it.
This site has been a great help to me.
Thanks again,
Adam
Old Mar 15, 2007 | 06:50 PM
alz's Avatar
alz
Is this a 4x4? When I encountered this, it was bad axle u-joints.
