1978 - 1996 Big Bronco
Oil Pump Question Part 2
Old Jun 26, 2002 | 09:03 AM
masterkiller214's Avatar
masterkiller214
I have just replaced my oil pump again and I still have no oil pressure. But this time when I start it up after it has sat for a while I have great oil pressure, but when it idles down after about a minute the pressure drops right back down and the engine starts knocking.I did notice that the oil pump gasket that I had put on previous was on wrong and a piece of the gasket had broken off. It was a small piece about the size of half a pinky nail. Could this be part of the problem? Could I have a blockage somewhere? If so is there a way to flush out the engine? Im using 5w 30. Should I go to a heavier oil to help with pressure? Help me please.
91 Bronco 302
Old Jun 26, 2002 | 10:00 AM
jmackie's Avatar
jmackie
I had almost the same problem with my 86. I replaced the oil pump
without any luck, my oil pressure would drop right off. It finally turned out to be my motor. Not saying this could be your problem. But it might be. Gaskets are cheap, try and replace it and see what happens.
Old Jun 27, 2002 | 01:59 AM
masterkiller214
I did replace the gasket and the rod and main bearings. The oil pump is new to. I think it is the engine and I have been pricing them. I just wanted to see if there was another way around it.
Old Jun 27, 2002 | 06:06 AM
Bob_VT's Avatar
Bob_VT
Old Jun 27, 2002 | 11:31 AM
jmackie's Avatar
jmackie
Price out a 351W. LOTS OF POWER
Old Jul 3, 2002 | 01:36 PM
cajunbronco's Avatar
cajunbronco
"I did replace the gasket and the rod and main bearings." Did you check the crank and rod clearance when you changed bearings?If the rod or crank journals are worn then replacing the bearings would'nt solve the problem.It sounds like you have too much rod or main bearing clearance.This is why you don't have any oil pressure.The knocking sound is also an indication.Have you checked the oil pressure with a mechanical gauge?
Billy
Matthew Sk
May 15, 2016 10:07 AM
Bubba Jones
Apr 23, 2016 11:52 PM
JimJr15
Nov 2, 2015 03:33 PM
51 F3 owner
Sep 3, 2014 11:27 PM
51 F3 owner
Aug 6, 2014 02:40 PM
