Steering Damper Shock Absorber!
Bought all that crap hardware to go with it.
Returned all that crap hardware to the store. :)
http://www.panix.com/~alvinj/file12/damper&shock.jpg
Just drill a 9/16" hole and counter-sink the edges good.
(reduces crack propogation)
http://www.panix.com/~alvinj/file12/damper.jpg
Mine's been welded for no real good reason. :/
The hose clamps were holding it fine, no kidding.
Welding medium carbon steel can result in failure if it ain't done right in at least three ways. Pre-heat, post-heat and welding method... not welding across the bar, only along the top and along the bottom.
I'm only here to show others what I've done.
I want to see what you come of with that's a better idea! :)
There's no way I could have come up with -the best- idea on one try.
Alvin in AZ
Not sure the forged type radius arm would work with my method. :/
The tie-rod bracket ain't hard to make if you've got a welder (any type), a drill, a 9/16" drill bit and a grinder. Better than owning that stuff is a friend that owns that stuff? :) The base is half of a 1" black iron water pipe. Don't slice it open until all the welding is done tho.
I would not never weld on an old rusty tie-rod like most of you guys have! :/
Not sure about the mechanism but hydrogen cracks or something really bad has shown up in my re-heat treated, rusty, old, factory, carbon steel knife blades.
Alvin in AZ
