driveshaft
Old Mar 13, 2007 | 03:35 PM
str8racing's Avatar
str8racing
driveshaft
replaced carrier bearing, put new u joints on supertruck now grinding from carrier bearing. need to drop down, who makes a bracket to drops the bearing for a better angle?
Old Mar 13, 2007 | 05:11 PM
Skandocious's Avatar
Skandocious
Procomp makes a high quality bracket for 4" in lifts, but I put it on my truck with a 4" lift and it dropped the driveshaft too far, now it's at a slight downward angle. I will soon replace the $45 bracket with a shim kit, which allows you to shim the carrier bearing down 1/4 inch at a time until its perfect. Tuff country is one company that sells such a shim kit:
http://www.tuffcountry.com/miscellan...drop-kits.html
-Chris
