Sponsored by: Real Truck
Gauges Malfunction
Old Mar 13, 2007 | 07:41 AM
ktodd's Avatar
ktodd
Gauges Malfunction
I have a 2001 F250 PSD which I bought used. It has a little over 100K miles on it and still drives and rides very good. The problem that I have is that the gauge cluster on the left side of the instrument panel (oil pressure, electrical, temperture and fuel level) do not work when I first start the truck. You have to drive the truck for 5-6 miles or further and then they will all of a sudden start working. Upon startup, the gauges will be at some level and they will go in the negative direction slightly before they begin to work properly. It sounds like a ground is loose but I wanted to poll the audience to see if anyone else has had this problem or might have a suggestion as to how to solve this problem.
