adjusting the ip
Old Mar 12, 2007 | 08:13 PM
Sml Mtr's Avatar
Sml Mtr
adjusting the ip
the previous owner put a new ip and rebuilt injectors on my truck in preperation for a turbo, i bought it before he got around to it.
where is the adjustment screw for the ip? i know not to turn it more than a flat at a time, but didn't want to touch anything till i was sure where the screw was.
also, i was considering changing the rear gear, it's a 4.10 now, was thinking of maybe going to a 3.55 or 3.73, any input on this? or where i could find a gear. it's a 10.25 sterling axle. i only tow lightly, an open car trailer with my drag car on it. 5500# total weight.
thanks
Old Mar 12, 2007 | 08:32 PM
brownieboy525's Avatar
brownieboy525
did you put a turbo on ? also do you have a pyro?? any intake or exhaust mods done yet??? if you dont have a pyro or any mods you should leave the adjust ment alone you could start melting things.
Old Mar 14, 2007 | 12:35 AM
Sml Mtr's Avatar
Sml Mtr
i have a pyro, intake is stock-ish. no ram air. exhaust is a 2.5 y to 4"
this thing runs way rich, no turbo. adjusted for one though. even on this new ultra low sulfur fuel it pours smoke when i have to hammer down. idling for 15-20 min will leave soot stains on my driveway.runs great though, i just want a little better mpg. if i'm easy on it it'll do about 14.
Old Mar 14, 2007 | 06:06 AM
brownieboy525
o sorry about that i thought you were turning the pump up not lowering it .
Old Mar 14, 2007 | 07:36 PM
KJLYPW's Avatar
KJLYPW
What are the stat's on your truck, 6.9, 7.3, year??? Sounds to me like you could easily turn down your fuel a flat at least, and get rid of the no power gained due to unburned fuel soot issue. With intake Mods you may get more power with that fuel setting, I would try that as well as turning down the fuel, if you don't have a pyrometer, you could be doing damage at high power output. If you do notice power loss that you don.t like you can always crank it back up!
Old Mar 15, 2007 | 12:15 AM
Sml Mtr's Avatar
Sml Mtr
it's a 92 7.3, it pulls harder at half to 3/4 throttle than full. mainly half throttle. the pyro is mounted in the y-pipe. at idle reads 300, cruising on the highway at 70 it reads 600. the intake is pretty stock, i removed the stock scoop and aimed the hose at a cold air source.
my main question is where is the adjustment at? the only thing i've touched on the ip is the fipl.
Old Mar 15, 2007 | 06:22 AM
fonefiddy's Avatar
fonefiddy
There's is a triangle looking cover, with 2 screws holding it, about the 3:00 position.
You'll need to rotate the engine, to get the adjustment screw to come into postion to turn it.
