I have a few questions. What kind of hp/torque numbers does my non-catalyst 86 460 have? It is all stock, and has a 4 barrel carb. When i work full time again in the summer i would like to eliminate the air pumps and emissions ****, and do a carb/intake on it and possibly headers. Would this make a big difference without doin the heads also, because im not getting into the heads. Is it worth the time and money to just do a carb an intake? Thanks, Jesse
any time you get rid of emmisions and do the mods you suggest you gain hp. mileage, and reliability. you can use your old intake, change the carb to a 750 cfm install headers. plug the egr valve, remove the vacum advance, set timing to 42 deg. @3000 rpm if the idle timing isnt where you like it, recurve the dist. to where the thing idles the best. get rid of all hoses and vac. lines. you only need 3 vac. lines. brakes, heater, trans. if 4 spd w/o ac. you only need 1. thats a fact.
So whats the point of the bigger carb? Since the stock cam runs out before 5000 rpms and 750 is overkill and hurts gas mileage with no horsepower benefit. A 600 carb like is on the engine without the emmissions curcuits in it would be a much better choice. Your advise on the timing and dist. mods will get him a blown motor for sure. Removing the vacuum advance just hurts gas mileage with no horsepower gain. I hope you did all these mods you recommend on your own truck, because you are badly inform.
the only thing i agree with is the 750 carb. thats about all your going to want with a stock setup and i know they can take that 750 if tuned properly and make some power. This is from experience as well im not just saying it so u can go throw on one there then say oh it runs like ****. It doesnt work that way you have to fine tune things mess with jets and idle mixture and what not. Only on a race car would i consider not running a vacume advance. I can't tell you what timing you will benifit from the most because all engines react different to timing. when you advance your timing too you want to pull the vacume line off the advance and advance it a couple of degrees go take it for a test drive ease onto it. If it detonates back it off a degree or so. you just have to keep messing with it tell its at your liking. if detonation is not that bad you might consider running a higher octane fuel and it could solve your problem. Thats your choice though.
I did an '86 460 for very similar reasons.
You really do not need an intake, the stock one performs quite well for any standard use. The carb is probably worn out, but the stock Holley is sufficient for your needs.
If money is a bit tight, the best use of your limited resources woiuld be to replace the camshaft and timing gears. Use a so-called "RV cam, and timing gears from a '70 460. Those will really wake up the engine.
Headers and all will certainly help out, but I would start there.
Change the cam and gears, then get a new intake and carb. Do those first.
If you have money left, then go for a new exhasuet system with headers and larger pipes.
Good luck, and let us know whow this works out.
By the way, FTE is the best place place to get information and share ideas. We do strive to keep it family friendly. Please do not wite anything you don't want your mother or your 6 year old daughter to read. Thanks, and we'll see you on the boards!
I would bet money that a 600 carb, tuned properly will equal or out horsepower the 750 with the stock cam in the motor. The 600 is good to right at 4500 rpm and thats all the stock cam is good for. To get a 750 to work best the cam needs to be changed to get your max RPM between 5000 and 5500.
you could also change out the timing gears for 429 timing gears and that will wake it up alot. not sure if 86 is the same as a late 70s besides the block differences, but I do know in late 70s the cam timing was retarded something like 4 degrees. bring that back to 0 would make one hell of a difference.
Faststang: You are right on the money! The straight up cam gear timing will indeed wake the 460 up. It will get better mileage too!
The 429/460 uses the same cam setup. The cam timing was retarded in '71 or '72 - not the late '70s, so I suggest using a '70 gear setup to get the best out of it.
so your saying late 70's did not have the cam timing retarded ? I would have thought it stayed the same like that up till they went to efi setups.
anybody that thinks im misinformed please call Troys Motorsports @ 307 367 6368 as i am tired of going to races around the country and seeing fords suck, because ours dont.....
You are recommending a set up that works at 500 to 700 feet in the air. This dude is in Georgia and they just don't have any altitudes that high that he can restrict his truck to. Below 2500 feet timing should be restricted to 38° max and with regular fuel probably a couple degrees less. So you really don't know as much as you think you do.
I am going to stick my $.02 in on this one. If you have the over 8500 GVW truck like mine, the exhaust is dual 2 1/2" pipes all the way to the muffler. My exhaust guru told me he could sell me a bigger muffler for around $400 in 1994, but if I removed the spark screens I would get the same thing free. I agree with the 600 cfm carb, I ran a low compression (9.7:1, early heads late block) 460 in a 1971 Mercury Colony Park wagon (5000+ lbs). I used a 600cfm Holley service carb on it. I did find that you can run 38-42 degrees total advance on these open chamber 460s with no problem on regular gas. The best carb I ever found for the old high compression engines was the 1969 428 CJ 735cfm Holley. It would wake one up and improve the fuel economy. On the cam sets, 1972 was the year Ford lowered compression and retarded the cams. Be careful buying timing chain sets for these, many parts stores will list 1 set for all non-roller chain systems. You will need to keep a vacuum advance if you want any kind of fuel economy other than single digits like a brand C big block.
On mine, I changed to a pre-'71 timing set, installed an open-element air cleaner and created a 4" single exhaust. I have the initial timing set at 12BTDC. Everything else is stock, and this beast gets up and goes. I can't imagine needing more, unless I was racing.
