Gas Tank
Old Mar 12, 2007 | 03:24 PM
guitarnik's Avatar
guitarnik
Gas Tank
i was wondering if anyone knew how to go about removing the rear tank on an f-150 and plugging the lines that lead to it. do they make plugs or do i need to make my own.
Old Mar 12, 2007 | 03:34 PM
lostin90s's Avatar
lostin90s
You will need to make own plugs. And I don't know about fuel return . I usually add tanks not take them off. Course most people don't put over 500 miles a week on my truck. Good luck
Old Mar 12, 2007 | 03:44 PM
gravydude's Avatar
gravydude
(Rusted right on those straps, right?) I usually run the truck about empty before removing the fuel tank. Either that or it drips out like usual. It's a pretty simple process. Just remove the Two straps and the in and out hose's. The hardest part is getting the inlet hose back on.
Old Mar 12, 2007 | 05:11 PM
guitarnik's Avatar
guitarnik
i am going to leave it off for other reasons but i already plugged the in and out lines and they dont leak do i need to do anything with the other hose the inlet i believe is what it is.
Old Mar 12, 2007 | 05:33 PM
93blueoval f-250's Avatar
93blueoval f-250
could the sender for the back tank work in the front?i might do the same thing
Old Mar 13, 2007 | 07:46 AM
guitarnik's Avatar
guitarnik
it should, im not real sure my tank was just rusted to crap and i dont use it anyhow.
