Offroad & 4x4
Winch
Old Mar 12, 2007 | 01:59 PM
brddog's Avatar
brddog
Trailering
Winch
Been thinking about getting a winch for my stock f-250.Is the warn xd9000 or the9.5ti portables enough winch for gettin me out?I also have a plow mounted on the truck which is gonna make the mount a problem.
Old Mar 12, 2007 | 02:25 PM
acheda's Avatar
acheda
If you decide to go electric, one option is one that quick-mounts into a standard 2" trailer hitch receiver. If you mount a receiver on the front, even with suitable reinforcement, you should be able to avoid problems with your plow. (If you already have a receiver on the back end, you may find that there are times when a winch on the back is useful - both for pulling yourself and for pulling others.)
Old Mar 12, 2007 | 05:06 PM
fishmanndotcom's Avatar
fishmanndotcom
o yes, that will suffice.... however just in case get a ****** block or two and some riggin hardware
-cutts-
Old Mar 13, 2007 | 07:44 AM
brddog's Avatar
brddog
Trailering
Archie, That is the type of winch I am thinking of.Thanks to both of you guys for the reply.
Old Mar 13, 2007 | 09:37 AM
acheda's Avatar
acheda
Mine is a Ramsey quick-mount 5,000-pound pull. Do as fishmanndotcom suggests and get a "****** block" so you can double back the cable and double the pull, because 5,000 pounds will not always be enough. Ramsey includes a high-current quick-disconnect coupler, but only a short cable. Hook the coupler cables directly to your battery with welding cable, or you will not get the full 5,000 pounds of pull. If you use it a lot, a second battery is also a good idea.
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Jan 22, 2011 02:34 PM
armyboy
Jul 15, 2007 02:40 PM
ronross
Aug 29, 2005 06:45 AM
tmehrkam
Feb 29, 2004 06:20 PM
