Sponsored by: Real Truck
Electrical problems?
Old Mar 12, 2007 | 11:17 AM
j-dawg's Avatar
j-dawg
Hey all, I am fairly new here and was wondering if anyone has experienced a problem similar to mine. My speedo and rpm guage (03 250 SD 5.4 @59,000mi)drop while driving and the ABS light comes on. I do not loose power in the engine and the speedo goes back to normal, ABS light goes off. It started doing this after a trip to the dealer for an oil change. It happens once to twice every day or two. Any ideas would help before I take her in. Thanks
Old Mar 12, 2007 | 12:07 PM
msgtg's Avatar
msgtg
Hmmm, sounds like a sensor but I'm not a pro. Can you pull your codes...that should help pinpoint the issue.
Old Mar 12, 2007 | 07:40 PM
ReAX's Avatar
ReAX
If it's just Speedo and ABS I would immedately suspect the VSS (vehicle speed sensor.) It's a little sensor on top of the diff, and I understand it's fairly cheap. The Tach kinda throws me. It could be a glitch in that the cluster gets flustered by the loss the of the VSS signal. Because of the ABS light, I would still start with the VSS.
Old Mar 13, 2007 | 12:52 PM
j-dawg's Avatar
j-dawg
Thanks for the info guys
