Sponsored by: Auxito
weak startup
Old Mar 12, 2007 | 06:45 AM
triton54's Avatar
triton54
weak startup
I have a 97 f-250 5.4 4x4, when i start it cold, hot warm whenever, it seems weak like i have to keep they key turned for an extra second. once it turns over its like a low rpm start then it climbs to normal idle instantly. never been a problem just a concern because a buddy of mine has a ram and he hits his key and its there is that the difference im going to have to live with or what?
Old Mar 12, 2007 | 02:31 PM
KingRanchMan02's Avatar
KingRanchMan02
Sounds like a IAC valve problem. You can try cleaning it but, from what I've read in this forum, this doesn't last very long. So, it is time to replace the IAC valve. Good luck!
Old Mar 14, 2007 | 07:10 AM
triton54's Avatar
triton54
i think i'll clean it to see if it makes any difference, if it does i'll replace it i just dont want to spend $90 if i dont have too but thanks for the feedback
