99 explorer, rear shocks
Old Mar 12, 2007 | 05:50 AM
tomo805's Avatar
tomo805
I'm wanting to change the rear shocks and have found that I need to remove the spare tire for easier installation. The problem I am having is that the lug wrench that is with my explorer will not fit into the hole in rear bumper to lower the spare. Has anyone encountered this. I'm just glad I have never had a flat tire to change. Any ideas?
Old Mar 12, 2007 | 10:31 AM
marragtop's Avatar
marragtop
You should be using the jack handle, not the lug wrench.
Old Mar 12, 2007 | 10:43 AM
tomo805's Avatar
tomo805
thanks, I had already found them just before you posted. I appreciate the help though. Looks like a real tight squeeze getting to the left rear shock.
Old Mar 12, 2007 | 11:13 AM
bingo begone's Avatar
bingo begone
Also, be sure you are using the correct end of the jack handle--its easy to use either end, and one works, one don't. And yes, i found out the hard way!
Old Mar 12, 2007 | 06:58 PM
tomo805's Avatar
tomo805
All is well now. The car rides like new, with the new shocks and a repaired stabilizer bar.
