Bought this car 6 months ago. It`s overall working fine, but lately i have had some problems with leaking cooling fluid. The fluid was very rusty so i treated
the engine with some cleaning from Bar`s. Then i flushed the engine and the rad. with fresh water. Put a new thermostat in, and added new cooling fluid.
Also put some Bar`s anti-leaking stuff in it. Everything looked to be ok for a couple of days. But today when i drove over the mountains it was leaking again.
The funny thing is that it seems to leak from another location now.
Could it be that i have too high pressure in the cooling system?
If so- any reasons? And sholdn`t the rad-cap reliefe the pressure over to the expansion-tank?
Sounds like a core tube has either been eaten away by bad coolant or a stone has punctured one.
Also could be the solder joint at the tank seam has broken loose.
I have replace dthe cor ein my radiator several times over the years, but the WVDOH loves to use salt here in the winter.
Does a number on everything metal.
The coolant was bad. And there is being used a lot of salt on the roads in Norway too...
Guess the radiator has to be taken out at some point then......
